MF40 Power Steering leak
/ MF40 Power Steering leak #1
RidgeRun
Massey Ferguson MF40
I have a MF-40 that has a leak in the power steering, but I cannot find the leak, no visible fluid leaks to the ground. The unusual thing is that it leaks while parked and not running. If it sits a day or two, I have to add about 6-12 ounces of fluid.
Any answers to this puzzle are appreciated.
/ MF40 Power Steering leak #2
Since you asked this question 4 years ago I assume you have found and fixed the problem. I’m guessing you have a pump shaft seal leak and the hydraulic fluid is leaking into the engine oil sump.
/ MF40 Power Steering leak #3
Since you asked this question 4 years ago I assume you have found and fixed the problem. I知 guessing you have a pump shaft seal leak and the hydraulic fluid is leaking into the engine oil sump.
He would also be gaining crankcase oil if the seal is leaking. If the tractor burns some oil that may not be noticed. The problem with that is without knowing it over time the engine oil is continously getting diluted with power steering fluid. This could damage the engine bearings.
2010 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2010 Ford F-150...
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
6' STACKING RAKE (A64276)
6' STACKING RAKE...
2027 . . (A67714)
2027 . . (A67714)
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
