GC 2600
   / GC 2600
I also have no manual for the new machine
Gc 2600
What oil do I use in the front diff ?
How much does it take?
When I refill do I just fill by the main cap or do I need to fill the part by the wheel also?
Is the hydro static oil and hydraulic oil all together?
What oil and how much will it take?
Sorry for all the questions, really appreciate it if someone answers them for me.
Danny.
   / GC 2600
I guess the only thing I left out is how much engine oil does the little Iseki take?
What grade is recommended?
   / GC 2600 #13
BUY THE BOOK, no just joking engine oil 15/40 or 5w/40 maybe 1 gal or a little more + or - ,hydro and hyd same don't know what type other then mobilfluid 424 or kubota super udt2 , front diff gear oil 80/90 or 75/90 syn should have dipstick on plug or a level indicator plug on the axle....
   / GC 2600 #14
Gc 2600
Danny.
Front axle takes 4 liters of same oil as the hydrostat.
Lift front of tractor with the loader (if it has one), place stands under front frame. Drain oil, rocking the axle will help drain it.
Hydro takes 11 liters, Kubota SUDT2 personal preference for cost/quality ratio. Due to branding issues, SUDT2 may not be available, Kubota has Premium UDT available in Canada. Check with the parts guy for equivalent.
Engine is 3 liters of Diesel rated oil. Personal preference is Mobil Delvac 0W40 synthetic from Canadian Tire. My tractor gets most of its use snowblowing.
Filters are best from your local MF dealer. Some can be sourced elsewhere, but in Canada it is difficult. I've used Dan R Equipment a couple times for ordering parts.
   / GC 2600 #15
I bought the service manual for my GC2610 and it says to remove the top plug on each side to allow air to escape and then fill until the hydraulic fluid comes to the centre of the gear that shows in the filler area.
   / GC 2600
Thanks a lot DMW I Appreciate your time!
   / GC 2600
Thank you not2old.
   / GC 2600
One more question guys. Then I promise I’ll leave you alone lol.
I’ve emptied the hydro oil and I seem to remember people talking about a screen filter.
Is there one? If so where do I find it?
Thanks again.
Danny.
   / GC 2600 #20
Wow! My tractor is 10 years old already? Yes def. buy the owners manual and if you can afford it the repair manual. I am looking at buying the repair manual this summer.
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2020 CATERPILLAR 242D3 WHEELED SKID STEER (A51242)
2020 CATERPILLAR...
Cat TH407C Telehandler (A52128)
Cat TH407C...
Club Car (A50324)
Club Car (A50324)
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
DMI 3200 Side Dress Bar (A50514)
DMI 3200 Side...
