2wd vs 4wd
/ 2wd vs 4wd #21
Any models you’d think would be a good fit? Go ahead and spend my money. It’s ok. :)
I just don’t have much to spend!
None in particular, but the older Deere and Case-IH tractors were reliable, simple, heavy duty and easy to work on.
How about a Case-IH Maxxum? Deere 4xxx? White makes great older tractors.
Judging by your seeder, I think you need more size & weight.
/ 2wd vs 4wd
My MIL has a 69 Oliver 1650 with a FEL. gas. Can’t find its lift capacity either. This would be nice as it’s free to use for me.
/ 2wd vs 4wd #23
Any models you壇 think would be a good fit? Go ahead and spend my money. It痴 ok. :)
I just don稚 have much to spend!
Look at open station 2wd JD 6XXX series. Everyone wants a cab when moving to this size, so open station are good buys.
When I was looking for an open station MFWD JD 5XXX series, I ended up with a MFWD JD 6415, for less $$$$ than the 5XXX series I was finding.
I got radial tires, Power Quad trans, Power Reverser, MSL loader, 2 rear SCVs and mid valve for the loader. 2500 hours.
/ 2wd vs 4wd #24
My MIL has a 69 Oliver 1650 with a FEL. gas. Can稚 find its lift capacity either. This would be nice as it痴 free to use for me.
If you like Cummins power, look at Maxxums. Cummins 5.9 power. Very good tractors and hold their value. If you really want to go crazy in size, look at Magnums Cummins 8.3L power. Insanely powerful.
Both models are highly sought after, plentiful and easy to work on.
/ 2wd vs 4wd #25
That Oliver 1650 is about 60 hp and almost 8000# hook it to your drill and see how it handles it.
I don't recall their lift capacity but it was quite good.
Depending on your terrain one thing on Olivers with the hydro power it was an under drive only unit,
and it free wheels going down hill if in the under drive mode.
They are a nice tractor a bit clunky on the shifting.
Also being gas it will be a bit thirsty when worked hard, and it will behave better on mid grade or better.
/ 2wd vs 4wd #26
/ 2wd vs 4wd #27
i congratulate you bro to move on quickly .
Unused 2024 HLA MB48 48in. Bucket Skid Steer Attachment (A66734)
Unused 2024 HLA...
2017 Ford E-450 Super Duty Shuttle Bus (A66736)
2017 Ford E-450...
220 VOLT 6IN SUBMERSIBLE PUMP (A67714)
220 VOLT 6IN...
2017 KOMATSU HM400-5 OFF ROAD WATER TRUCK (A65056)
2017 KOMATSU...
Boat Motor. (A66738)
MAGNUM TRANSFER PUMP (A67714)
MAGNUM TRANSFER...
