Hydraulic Pump Sizing Question
/ Hydraulic Pump Sizing Question #1
Charles84
JD 420
EDITED TO TRY TO CLARIFY BETTER:
What i'm trying to accomplish is to run 2 variable speed piston pumps off of the Flywheel of a 35hp Briggs Vanguard to power 2, or possibly 4 hydraulic wheel motors. I am trying to understand whether putting the second pump in Tandem on the Flywheel shaft will create significant extra resistance, thus requiring a significant amount of extra torque from the engine.
The Surplus Center 'Horsepower to Drive Hydraulic Pump' calculator states that a 34hp Gas engine (17 hp Electric) will drive a pump at 13gpm @2000 psi. I am trying to figure out how these calculations relate to driving 2 of the same pumps in tandem. Would you require a 68hp Gas engine to drive (2) 13gpm variable displacement pumps @ 2000 psi in Tandem? Or could you drive 2 of them off of the same 34hp engine? I don't understand the torque requirements or the resistance that is occurring inside the pumps, and for some reason I'm having really hard time trying to grasp these concepts.
/ Hydraulic Pump Sizing Question #2
I’m lost at what you’re trying to accomplish.
Please refer to my edited post at the beginning of the Thread.
/ Hydraulic Pump Sizing Question #4
Using the Surplus Center calculator it requires a 33.8 hp gas engine to power a single 13 gpm pump @2000 psi. If that info is accepted at face value you would indeed need 67.6 hp to run two of the same pumps at 2000 psi.
/ Hydraulic Pump Sizing Question #5
That's right. you need to supply twice the HP to do this. No matter how you hook up the two pumps, you are asking them to do twice the work of one pump. So you will have to supply twice the hp. into them to get that much flow out.
rScotty
/ Hydraulic Pump Sizing Question #6
Charles,
Do you mean two variable volume piston pumps vs saying variable speed?
If yes, are these manually controlled for displacement like HST drive on lawn mowers. If Manual displacement control you can reduce displacement which will let pressure increase with a smaller engine. I.e. yes you can run two pumps of this style on your 35 HP Briggs.
Charles,
I meant to say variable displacement. Thanks for catching that. I'm assuming variable volume is the same. Yes, this would be a manually controlled displacement HST drive.
Looking to run two Hydro-gear PR pumps in tandem off the flywheel shaft of the Briggs Vanguard 35hp (and one gear pump on a stub shaft from the other side of the engine) Will be powering 2 hydraulic wheel motors with the piston pumps and a FEL/Backhoe with the gear pump. Gear pump won't be in use when maxing the piston pumps. I was initially concerned about not having enough torque at the wheel sprockets,(This is a track vehicle) but it appears with 35hp there will be plenty, and a modest top speed of 6.82mph. I'll start a Build thread once I have finalized the schematics and I'm ready to actually start building. I have a stripped down JD420 that i will be using as the core. The 35hp will barely fit under the hood, with some minor modifications to the exhaust. I want to keep this looking as much like a Regular John Deere, minus the tracks of course.
/ Hydraulic Pump Sizing Question #8
Yes variable volume would be same as variable displacement.
Good luck with your build.
2012 GMC SAVANA VAN (A67714)
2012 GMC SAVANA...
2012 KENWORTH T800 HYDROVAC (A67714)
2012 KENWORTH T800...
2013 MITSUBISHI FE 4X2 S/A 20FT BOX TRUCK (A69167)
2013 MITSUBISHI FE...
Ingersoll Rand RT-706H (A64911)
Ingersoll Rand...
2013 WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
