Massey Ferguson 1734E Line ID
   / Massey Ferguson 1734E Line ID #1
buzzsaw07
Western Pennsylvania
Massey Ferguson 1734e
I need help in identifying the hydraulic lines on my MF1734E with a L105E loader. I have attached pic with the lines numbered on joy stick. Do I have a power beyond port?View attachment 648680
   / Massey Ferguson 1734E Line ID #2
You do have PB. There should be letters stamped on the valve.
P=power in. Should be #3 in your picture.
T=tank. Should be #2 in your picture.
C=power beyond. Should be #1 in your picture.
Double check me but I believe that is correct.
Thank You for the info. One other question, would I be able to plumb into the plugged port that is above the line #1 in the picture to pick up the power beyond. I am planning on adding a third function? I am new to hydraulics.
   / Massey Ferguson 1734E Line ID #4
Short answer is no.
I would have to know what valve you are wanting to use in order to help. There is several different options to get 3rd function and it makes a difference on how you connect. What valve are you looking at?
   / Massey Ferguson 1734E Line ID #5
Nearly all CUTS have open center hydraulics. The way that works is the valves are plumbed serially. Until you operate a valve, the flow goes in the in port and out the PB port (or tank port on valves with no PB). When you operate a valve the flow is diverted out the work ports.
The PB on the loader valve should be connected to the 3pt hitch valves. Those are usually inside the transmission, often near the back of the tractor.
Usually when you add a valve it goes in line between the loader valve and the 3pt. So you'd disconnect the hose that goes from the PB port to the 3pt and insert your new valve there. The new valve can be one with a PB port, in which case it's PB port would now feed the 3pt and you'd tee the tank line into the tank line from the loader valve. Or it can be one without a PB port, in which case you'd run its tank port into the 3pt. With those valves you need to read the specs to make sure the tank port is rated for the full system pressure (2200 psi or so). When you operate the 3pt, lines from the pump through all the valves ahead of it in the chain will see the pressure needed to raise the 3pt.
Short answer is no.
I have not selected one yet. Do you have any recommendations?
Thank You, That explains a lot and I appreciate the information.
   / Massey Ferguson 1734E Line ID #8
I would recommend ordering from Everything Attachments. They sell a kit that is complete with everything you would need. They also are very good at helping you over the phone with installation.
   / Massey Ferguson 1734E Line ID #9
Typically you would add the 3rd function valve as in sketch below... Yes this is for MF GC 1705 to 1720...
BUT IT DEPICTS the ports as "P" (power in) and "PB" (power beyond) and "T" (tank)...
Yes its a corrected drawing because MF got it wrong in MF 1705 to 1720 series manual....
Typically your added valve would be "6" in sketch... IT could also be for BH hydraulics or some 3PH device as a log splitter or a hydraulic powered "whatit"..
Shop manual for you 1734 should have hydraulics diagrams...
Dale
I checked the valve body and the only letter stamped on it is an R> were line 2 goes into valve. It also has an R> pointing to the plug between lines 1 and 2
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2017 Nissan Frontier Ext. Cab Pickup Truck (A55852)
2017 Nissan...
VOLVO EC240CL LONG REACH EXCAVATOR (A52705)
VOLVO EC240CL LONG...
