How to pick a tiller
   / How to pick a tiller #1
Ffphil
Buckley, washington
Yanmar YT359C
Hey all, I have a YT359 60hp tractor and am looking to buy my first tiller. Don't let the size of the tractor fool you, I am a greenhorn. I have found a used RSB 1500 and RSB 1503 both for about $800. I only need it for the wifes garden and don't have any plans beyond that yet. I am searching the past post but would appreciate any direct input. Also I heard from a local dealer you need to size the drive line from the tractor to the tiller? Any thoughts here or how to knowledge? Thanks Phil
   / How to pick a tiller #2
The length of the telescoping PTO shaft sometimes needs to be shortened to fit your model tractor on all PTO-powered implements.
When you go into a swale the shaft will telescope shorter. Shaft needs to shorten without bottoming out.
When you crest a ridge, shaft will telescope longer. Must be long enough so two sections do not separate. If shafts separate, inboard end can kill you as it swings @ 540 rpm.
Multitude of videos on you-tube showing how to evaluate and cut PTO shafts.
   / How to pick a tiller #3
With a used tiller,, the PO could possibly have SHORTENED the PTO shaft,,
so you may need to purchase a new one to get enough length,,, :eek:
That could easily add $300 to your $800 purchase price.
I know my 60HP tractor has L O N G three point hitch arms,, and I always need a long PTO shaft,,,:confused:
What size tiller do you run? I am assuming having extra HP is less of a problem than having too much?
Can someone explain forward and reverse tilling and what that means to me?
   / How to pick a tiller #7
Forward rotating tillers are 90% of tiller market. Forward rotating tiller tines push tractor forward so they require only a small amount of tractor power.
Reverse rotation tillers are a small portion of the tiller market. Primarily used for "breaking" new ground, eliminating need for a turning plow. Reverse rotation tines pull against tractor forward progress, therefore dig in more. Heavier built. Weight helps penetration. Needs 35% to 50% more PTO horsepower for same tiller width, relative to forward rotation tillers.
Some Kubota/Land Pride tillers can be changed from forward to reverse tine rotation.
Thanks Jeff. Guess I need to update my profile. I graduated from the old 22hp Hinnamoto to Yanmar YT359C 65hp.
   / How to pick a tiller #9
65hp should open up many options, my brother has some 55hp tractors and a 7' or 8' Northwest tiller (that thing is a beast, pretty sure it's near 2000lb) and it works on soil after the top has been cut, I think that's what he's doing... tiller is a little overkill but he got a killer deal on it...
The PTO length is important, the shaft on my finish mower was too short when I got it and it decoupled, conveniently it just stalled my little tractor and didn't even hurt the shaft... fixed the issue by installing a one way clutch which adds like 5" to the PTO length...
Does anyone have experience with Maschio tillers? I am looking at A180 or H185. It seems the 65hp of my tractor is a bit much for most tillers. The dealers around here will sell woods, landpride, frontier for about $2800 but they seem to be on the edge of just big enough. Im afraid the tractor will damage the running gear. Any thoughts?
1 guard rail (A49346)
2011 Ford Utility Econoline Van (A50515)
2011 Ford Utility...
1265 (A50490)
1265 (A50490)
2013 Chevrolet Cruze Sedan (A50324)
2013 Chevrolet...
2000 Mercedes-Benz S-Class Sedan (A50324)
2000 Mercedes-Benz...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
