Batteries -- what is the dif?
   / Batteries -- what is the dif? #31
With all my Battery Tenders don't really need a Minder but maybe I should get one and rotate it around with my Tenders. Would think an occasional desulfating would be good?
I have 4 Battery Minders, and 14 Battery Tenders.
What you suggest is what I do.
And.....whenever a Tender fails, I replace it with a Minder.
   / Batteries -- what is the dif? #32
Okay good to hear... will follow your plan.
   / Batteries -- what is the dif? #33
Sulfation generally happens when you leave a battery in a discharged or partially discharged state. The longer you leave it that way, the worse the sulfation. Since batteries self-discharge over time, they will eventually get sulfated if they are left unattended (i.e. not on a battery charger or not regularly used in equipment that recharges the battery). If you keep your batteries fully charged, there is very little chance of sulfation. However, simply recharging a battery will not remove sulfation that has already happened. Your battery tenders are definitely helping avoid sulfation, but putting them on a desulfating charger from time-to-time is also a good idea.
   / Batteries -- what is the dif? #34
I do this and now have two Minders...
Just wish they made a 6v Minder. Called and was told they did at one time but had to re-engineer to be able to meet new energy use requirements decided from a financial point it didn't make sense at the time...
I have more 6v than 12v
   / Batteries -- what is the dif? #35
What about putting two 6V in a series and put your minder on them that way?
SR
   / Batteries -- what is the dif? #36
Yes... it works with a jumper to put them in series.
   / Batteries -- what is the dif? #37
NOCO makes some good chargers, and offers a variety of 6V chargers (NOCO Chargers). They are smart chargers and can safely be left on the battery full time. They are temperature compensated and have a desulfation circuit. I still prefer the BatteryMinder chargers, since their desulfation works continuously whenever it is connected to the battery, regardless of whether the battery is actually charging or in "float/maintenance" mode. The NOCO batteries shut off the desulfation once the battery is charged. (This can mean it takes a number of charge cycles to fully desulfate a battery). Still, they are very highly regarded chargers.
I have one of their 2 bank 12 V chargers that I keep in my antique military pickup with a 24V electrical system. (I prefer charging each battery individually, rather than using a single 24 V charger).
   / Batteries -- what is the dif? #38
That is a lot of chargers, and a good strategy.
You have had some Tender failures? What about Minder failures? How many years do you get out of each?
   / Batteries -- what is the dif? #39
I have not had one go bad from either brand but only 2 Minders and maybe 16 tenders... several models
   / Batteries -- what is the dif? #40
I've never had a Tender go bad either a couple are 10 years old with pretty much constant use.
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A59575)
2007 TEREX ADVANCE...
2013 VOLVO EC250DL EXCAVATOR (A60429)
2013 VOLVO EC250DL...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56436)
2019 Krause...
