Batteries -- what is the dif?
   / Batteries -- what is the dif? #31
With all my Battery Tenders don't really need a Minder but maybe I should get one and rotate it around with my Tenders. Would think an occasional desulfating would be good?
I have 4 Battery Minders, and 14 Battery Tenders.
What you suggest is what I do.
And.....whenever a Tender fails, I replace it with a Minder.
   / Batteries -- what is the dif? #32
Okay good to hear... will follow your plan.
   / Batteries -- what is the dif? #33
Sulfation generally happens when you leave a battery in a discharged or partially discharged state. The longer you leave it that way, the worse the sulfation. Since batteries self-discharge over time, they will eventually get sulfated if they are left unattended (i.e. not on a battery charger or not regularly used in equipment that recharges the battery). If you keep your batteries fully charged, there is very little chance of sulfation. However, simply recharging a battery will not remove sulfation that has already happened. Your battery tenders are definitely helping avoid sulfation, but putting them on a desulfating charger from time-to-time is also a good idea.
   / Batteries -- what is the dif? #34
I do this and now have two Minders...
Just wish they made a 6v Minder. Called and was told they did at one time but had to re-engineer to be able to meet new energy use requirements decided from a financial point it didn't make sense at the time...
I have more 6v than 12v
   / Batteries -- what is the dif? #35
What about putting two 6V in a series and put your minder on them that way?
SR
   / Batteries -- what is the dif? #36
Yes... it works with a jumper to put them in series.
   / Batteries -- what is the dif? #37
NOCO makes some good chargers, and offers a variety of 6V chargers (NOCO Chargers). They are smart chargers and can safely be left on the battery full time. They are temperature compensated and have a desulfation circuit. I still prefer the BatteryMinder chargers, since their desulfation works continuously whenever it is connected to the battery, regardless of whether the battery is actually charging or in "float/maintenance" mode. The NOCO batteries shut off the desulfation once the battery is charged. (This can mean it takes a number of charge cycles to fully desulfate a battery). Still, they are very highly regarded chargers.
I have one of their 2 bank 12 V chargers that I keep in my antique military pickup with a 24V electrical system. (I prefer charging each battery individually, rather than using a single 24 V charger).
   / Batteries -- what is the dif? #38
That is a lot of chargers, and a good strategy.
You have had some Tender failures? What about Minder failures? How many years do you get out of each?
   / Batteries -- what is the dif? #39
I have not had one go bad from either brand but only 2 Minders and maybe 16 tenders... several models
   / Batteries -- what is the dif? #40
I've never had a Tender go bad either a couple are 10 years old with pretty much constant use.
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
Case IH 330 Turbo Till (A59814)
Case IH 330 Turbo...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
1989 Ford LT9000 Log Truck, VIN # 1FDZU90T2KVA25137 (A57453)
1989 Ford LT9000...
2014 Ford F-150 4x4 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A57453)
2014 Ford F-150...
