What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #1,112
OK, I was figuring higher. I'm trying to figure out how to handle one if I have to take it off the tractor and get it on a trailer to go to a tire shop for any reason. Under 200, I have tools to handle. Over that would be different. Still thinking about one of the HF shop cranes or maybe the wheeled car dollies. Not sure how easily the shop cranes move when loaded.
Well whatever you choose but i didn't go with the rim guard it was too much money i use rv antifreeze and water have a tractor it has been in for 10 years when i got a puncture its non toxic and way cheaper just let it drain enough to handle it and most likely if you need to go to tire shop it will not be full of rim guard anymore! I just took a old compressor tank and removed a fitting fill with water then hook up air hose to it pump that 10 gallon tank into tire then repeat fist tank is rv antifreeze its so much cheaper yes a day of work to complete all 4 wheels on my tractor but saves more than i make in 8hrs!
I walked around it to get the long handled shovel to plant the Cherry tree I just bought because the ground is too muddy to drive the tractor over.
   / What did you do on or to your LS Tractor today? #1,114
A bit of seat time cleaning up this morning. This is second load. 1st was 10ft pallet, tools, extra material, other ladder, etc
116.6 hrs
Fire Tender Duty
I've had three piles of brush waiting for the right weather. I had it twice before but couldn't get the piles to stay burning. Finally got the right combination today and got two of them going. Spent the next few hours pushing wood to and into them and stirring them up to keep the hot spots open.
Still have one to go and a few more small trees to come down. They may have to wait until next fall now.
   / What did you do on or to your LS Tractor today? #1,116
Loaded my XR4155HC yesterday and left at 5 a.m today, headed up to RCO Tractor in Spicewood to get some warranty work completed.
345 hours.
Hoping to go get it by Thursday or sooner.
   / What did you do on or to your LS Tractor today? #1,117
   / What did you do on or to your LS Tractor today? #1,118
Finally remembered to take a few pictures! I have been running the tractor just once a week to bring a bucket of firewood in, so not much seat time until this week.
We are under a stay at home order here (Happy to comply , more tractor time)
So thankful I can self isolate out in the woods with my tractor & chainsaw!!! :cool2:
Finally got around to making a portable tool box for holding a log chain, saw, gas, & oil etc. I replaced the bungee with a ratchet strap since the pics were taken. Tractor won't fit in my garage with ROPS up, my land is flat so I rarely use it.
The box can be removed in less than a minute.
2020-03-27_14-22-18_476.jpg 2020-03-27_14-22-40_632.jpg 2020-03-27_14-22-53_523.jpg
   / What did you do on or to your LS Tractor today? #1,119
Also moved rotary cutter closer to garage for pre-season check-up.
   / What did you do on or to your LS Tractor today? #1,120
in the last few days I've finally been able to get out and get some yard clean up started! I've picked up 3 1/2 buckets full of limbs and burned, moved a pile of firewood, moved some dirt to a few low spots in the yard and spread. Getting ready to move the bush hog and the tiller up to the shop to prepare for the upcoming garden season. Next project is to level off the area next to the carport so I can add a lean too roof and pour some concrete, going to build an outdoor kitchen area there for the grills, griddle, and outdoor refrigerator
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2017 Ford F-250 (A55973)
2017 Ford F-250...
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
2001 Freightliner MB55 Chassis Bus (A56858)
2001 Freightliner...
2015 Infiniti QX60 SUV (A56859)
2015 Infiniti QX60...
2017 JOHN DEERE 323E SKID STEER (A52709)
2017 JOHN DEERE...
