How to ensure concentric axles on a lawn roller?
   / How to ensure concentric axles on a lawn roller? #11
I actually figured out a solution last night that I think will work well. It would be tough to describe in words and I don't have pictures yet, but part of it involves running a pipe through the tank to get the flange bearings mounted correctly at each end. Then I'll remove the pipe before filling the tank with concrete. For the frame I'll use a single length of axle rod and weld both sides of the frame rail to it, then cut the rod to separate. That will allow me to square things up together. Those two things should keep everything pretty darn close to concentric and axial. I'll post pictures eventually.
Sometimes I do my best design work in my head while I'm trying to fall asleep...
Rob
Here’s a pretty easy way to find the center
Skill Builder: How to Find the Center of Any Circle | Make:
   / How to ensure concentric axles on a lawn roller? #12
   / How to ensure concentric axles on a lawn roller? #13
Could you weld a stud plate to the tank. Run all thread into the tank like rebar with some protuding outside. Then weld your shaft stubs to a second plate with over size holes. Locate the shaft and shim between plates to get concentricity. Then weld when set after final assembly and test drive.
gg
   / How to ensure concentric axles on a lawn roller? #14
The way I would do that is to get a couple of pieces of pipe the the 1" rod will slide into. Put a big notch in the end of the pipe, reason will be explained. Then drill a small hole in each end of the tank. Use a laser pointer set up on a stand a foot or two away from one end and shine it thru the 2 holes you just drilled. Once that is aligned, take the pipe with the notch in it and put the notch against the tank and align it on the laser beam. Tack weld it into place, then slide the 1" rod into the pipe and tack weld it to the tank. The purpose of the notch in the pipe is 1) to allow access to the tank and laser beam for alignment and 2) access to the 1" rod to tack weld it to the tank. Then cut off the pipe and finish welding the rod it to the tank.
   / How to ensure concentric axles on a lawn roller? #15
I'm building my own lawn roller out of an ancient water softener tank. It is 12" diameter and about 45" long. I need to weld 1" solid rods on each end to attach the frame and bearings to. What would be a good way to keep them concentric? i.e. Parallel and inline so everything is straight?
Or would it be better to attach the bearings (I'm using flange bearings like in the picture below) to the tank and have the axles be on the frame? It may be easier to line things up and weld everything straight & plumb on the frame instead of making the axles straight/plumb/concentric on the tank. To do that I'd just have to make sure the bearings are flat to the plane of the tank ends.
Thanks,
Rob
Might get a pointer or two from these, they all seem to prefer mounting the bearing on the frame.
Page 18, https://degelman.com/assets/manuals/143044-LR2036.pdf
Page 34, https://www.ritewaymfg.com/images/dealer-resources/F_SERIES_ROLLER_FEB_2016.pdf
All good info. But I think I have a solid plan in my head now and am working it. The simplified explanation is that I will weld a single piece of axle tube to both frame sides at once, with everything squared and lined up, then cut the axle to separate. Then I'll assemble the frame around the roller and use the axles to locate the bearings on the ends of the roller. Hard to explain in words but it makes sense in my plan.
Rob
   / How to ensure concentric axles on a lawn roller? #17
Or, a 33 1/3 LP album should locate the center of a 12" tank. I'd use "ABBA's Greatest Hits".
I had to noodle through that one before deciding that Air Supply might be my first choice :D
   / How to ensure concentric axles on a lawn roller? #18
To find the center of the tank lay it on a flat surface, then with a framing square at a right angle to the tank measure from the flat surface to where the square touches the side of the tank. Transfer this measurement to the ends of the tank, rotate the tank 90 degrees then mark the ends again.
   / How to ensure concentric axles on a lawn roller? #19
Rob
I didnt build a roller, but its kinda close :) This was a 16" piece of sch. 80 pipe. It is now my new pasture aerator (yes I can fill with water, if needed) I cut out the end plates then found center and mounted my stub axles. The bearings are frame mounted using the same spacing off of the main tube. The tines are placed in a v-shape and are 1/2" plate, 4" long width.jpgbearing locate.jpgaerator 2.jpgaerator.jpg
Making good progress on the lawn roller. At this point I have the frame about 2/3 done, plugged the pipe holes in the tank, fabbed the flange bearing plates and got one side mounted, axles done and filled it with concrete. It's all coming together well. The tip above about finding center worked well for the flat end. For the domed end I used a carpenter's square and measured from various locations (same distance as the bottom) and found center that way.
This is the basic mock-up of how the frame, axles and bearings will work:
Here's how I made sure the axles were lined up with each other and the frame. I used a hole saw to cut a 1" hole in both frame sides while they were clamped together (backwards), then I ran a single rod through both with enough separation between the frame sides to allow me to cut the axle in half after welding. This also allows the axles to go through the frame to weld on both sides.
This shows the axles completely welded up. Added gussets to support them. They are welded around the rod on both sides of the angle iron, along both sides where the axle that touches the frame and, of course, at the gussets. Should be stout.
Bearing support plate mounted on one end:
Filled the pipe thread holes where the softener's original plumbing went through:
Had to make room for the bolt heads for the bearing plate on the other side. This was so the plate can rest flush and be welded to the tank end. That's not done yet because I had to fill the tank with concrete first.
Should be done by tomorrow. Just have to add the back plate across the frame rails for stability and to hang suitcase weights off of and then make a hitch at the front. The way I've designed it I can remove the tank from the frame and take the bearings off. This will be useful if I have to replace the bearings or other fixing.
Rob
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
CATERPILLAR 259D SKID STEER (A51242)
CATERPILLAR 259D...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
