2032R Rated PTO Speed and Rated Economy PTO Speed Lit
/ 2032R Rated PTO Speed and Rated Economy PTO Speed Lit #1
RSidetrack
John Deere 2032R
All,
I have an interesting situation with my 2019 2032R. Both the Rated Economy PTO Speed and the Rated PTO Speed lights are lit on the instrument cluster.
Now I will admit I don't know if the Rated PTO Speed was always lit and I got used to it, but what triggered my attention was the Rated Economy PTO Speed indicator is lit. In the manual it says that this isn't used, but darned if it isn't lit up.
When reading the manual I see the Rated PTO Speed indicator is mentioned for using the rear PTO, but I have the lever set to Mid PTO only. I have tried moving it all the way to rear only and back to mid only and the lights are still lit.
So I am not sure if something is going on which is causing both lights to light up, in which case what would trigger this, or if I have some sort of glitch happening.
It is under warranty, but figured I would reach out here first to see if anyone has any thoughts before I run down that avenue.
Thanks!
/ 2032R Rated PTO Speed and Rated Economy PTO Speed Lit #2
Maybe it's just the limit switches on the levers that are getting stuck. It can happens some times with moisture and dust.
That's a good thought. I haven't done my Spring Cleaning of the tractor yet so will see if I can manage to find and check/clean them while doing so.
2020 CATERPILLAR 259D3 SKID STEER (A62129)
2020 CATERPILLAR...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
207274 (A52708)
207274 (A52708)
2020 DRAGON ESP...
KJ K1220 12'x20' Metal Shed (A60463)
KJ K1220 12'x20'...
