New Holland 68 square baler
/ New Holland 68 square baler #21
Buying a new chain is a good idea. I forgot to mention that the number of links also matters.
Thanks if chains are replaced should all be replace they look like 2040 and 2050 chains. The one that's in the 68 that controls the hay rakes I have no idea what they are but are pretty darn big
/ New Holland 68 square baler #23
And I'll add, when you are ready to test cycle the baler again don't use your tractor. Do it by hand turning the flywheel. Once it will turn a complete revolution without problems trip the baler and cause it to tie without twine first. That will test the timing of the plunger/needles. All of this should be done by hand so you don't break something else in the process.
If you can get the baler to complete these functions without locking up or breaking something then you can load it with twine. Hook it to your tractor and hand feed the baler in an attempt to produce a bale. Understand you have to fill the chamber clear back to the chamber adjusters before it's going to make a successful tie.
Once you are to that point, then the fun begins. Learning how to adjust the chamber for bale tightness. Learning how to adjust the knotters to get a successful knot.
Very steep learning curve. I've saw men use a square baler for years and never get to the point they could make a good bale. :)
Thanks you are making me want to sell them and just keep rolling my hay :)
/ New Holland 68 square baler #25
Our Hayliner 68 was amazingly reliable. We just had to keep it greased and oiled, and change out the occasional pick up teeth. Oh ya, and never let it get out of time.
That's good to know... I wish I could post pictures it's way out of time plunger hits needle block when spent by hand.
/ New Holland 68 square baler #27
May I ask how number of links in a roller chain matters??
No matter how many links the chain has when chain is installed there's going to be the same number of links on the drive side(tension) of chain between the drive & driven sprocket & normally with an idler taking up slack in chain on opposite un-driven chain side of sprockets.
Thank you,Jim
/ New Holland 68 square baler #28
You're probably right. I know that on the "rake that pulls the hay in, the chain not only pulls it horizontally, it also moves it vertically up and out of the way on the return stroke. All I remember from 50 years ago is that we were meticulous on the timing and keeping the chains intact.
/ New Holland 68 square baler #29
I've operated/repaired small sq balers since the late 1960's & I can't envision how number of links in a roller chain will affect timing of moving parts. I know it doesn't affect JD small sq balers which is what I'm more familiar with & own.
How do you upload pics on here?
One other thing I read about is the rod under the rake. I.am going to remove it.
/ New Holland 68 square baler #32
When replying look at lower RH corner of page for box labeled "go advanced",click on that box then click on box labeled "manage attachments" a larger box will appear then just follow instructions. Photos I upload must be saved to my computer. If you're accessing TBN by cell phone my info may be incorrect.
Good Luck,Jim
/ New Holland 68 square baler #33
Be very careful about what parts you desire to remove!! The parts installed when baler was new were installed for a very good reason.
Reason being is its bent and I am sure it won't be the last time it gets bent. I read a bunch on it and it seems alot of people have removed it with no ill effects.
The baler was out of time extremely bad
/ New Holland 68 square baler #37
If the baler is timed and adjusted correctly that bar will be there forever. I spent more than 15 years servicing NH balers in eastern NY and western CT. I wish you luck, keep asking questions.
/ New Holland 68 square baler #38
When the chain wears,--it gets longer---pins wear rollers wear,---chain gets WAY too long and screws timing up! It's not JUST link count that matters, its how long each link is!--gotta factor that into the problem! Say you have 100 links that are 1" long when new, then after many thousand bales in the dirt, each link is now 1.2", now the 100 links are a total of 102 inches---way too long,--yes they have tightners BUT the extra length throws the geometry way off down the line.
Hope this gives an idea of how important this is on NH balers!--Might not bother green ones, BUT NH is yellow and red and they picky! LOL!!
/ New Holland 68 square baler #39
Sonny580
I agree roller chains wear as do the sprockets that the chains operate on. I disagree that one can't time and keep in time a small sq baler utilizing a worn chain especially the green ones. My main experience operating/repairing small sq balers has been with JD small sq balers & the later model JD design which have been in existence since the early 70's & these models only have ""2 chains to contend"" with while some other brand balers have several more chains. I have only timed a very small number of NH sq balers so my NH sq baler experience is very limited!!.
Please explain on NH sq baler with a worn chain if chain remains snug how timing can be affected?? The amount of chain(links) on the ""drive side of sprockets remains the same"" no matter if chain is new & same # of links if worn. Does it take numerous(many)/ revolutions of sprockets for the stretched(worn) links to get mechanism timing off?
Thank You,Jim
/ New Holland 68 square baler #40
TxJim
You may well be right. I am relying on memory from 50 years ago. I agree that the amount of chain(links) on the ""drive side of sprockets remains the same"" no matter if chain is new & same # of links if worn. . That would apply to the chains on the left side of the baler that drive the needles, knotters, etc.
What I was referencing is the chain that drives the "rake" that pulls the hay into the plunger. As I recall, that arm is connected directly to the chain because it pulls the hay in laterally, and then follows the chain UP around the sprocket on the return stroke so in clears the new hay brought up by the pick up teeth. As I recall, the number of links mattered there so that a certain number of revolutions equals a certain number of strokes each and every time. If that gets out of time, the plunger hits the "rake".
Again, you may be right. This is just how I remember it.
THUNDER CREEK 460 GALLON FUEL TRAILER (A60736)
THUNDER CREEK 460...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
