Grading land with boxblade
/ Grading land with boxblade #1
keith27581
Mahindra 2538
I have a piece of land that used to be a tobacco farm, there is an area that still has the crop rows that I need smoothed our. I am a new tractor owner and am learning as i go. Will I be able to level this area out with a box blade? Does anyone have any advice?
The rows run north/ south, Would it be best for me to go in line (north/south) with the scarring teeth down, or would it be best to go East/west?
My tractor is a Mahindra 2538 with a Mahindra HD 5 box blade, soil type is clay ( north central NC).
Thanks in advance for any help!
/ Grading land with boxblade #2
This is totally confusing. I suggest you hit the EDIT POST key, then revise it.
LINK TO T-B-N ARCHIVE: how to use a Box Blade site:tractorbynet.com - Google Search
/ Grading land with boxblade #3
Welcome to TBN.
Without knowing what your rows look like now...
I think first crossways on the rows would be a miserable ride. I would probably go lengthways, then two opposite diagonal passes.
Bruce
/ Grading land with boxblade #4
Seems clear enough to me.
The OP simply wants to even out/level the old raised tobacco rows.
He is looking for advice on the best way to accomplish that.
On a first pass anyway, I think pulling the box blade in the same direction as the old rows would be the only way.
/ Grading land with boxblade #6
Welcome to TBN.
Bruce
Exactly what I'd do.
Scarifiers only used if the dirt is hard. If the BB will slice it without scarifiers that would be the method.
/ Grading land with boxblade #7
Plan on it taking a few passes. Maybe a couple passes going "with" the rows, and then once they're knocked down enough that you can stand it, go "across" the rows. Then a chain harrow or drag pulled around a few times as a finisher.
Take a few pics and post them as you go. We like tractor pics.
/ Grading land with boxblade #8
I agree Slim. Patience is a virtue in projects like this. Bingo on the pics!!!
/ Grading land with boxblade #9
Always on the first time over a field with ridges or row crop, we will always run a slight diagonal with the rows with any tillage equipment. Pics would definitely help us help you with ideas , if there is much trash ( crop residue) left over a box blade may try to pile up on you.
/ Grading land with boxblade #10
I would think a disc would be in order, then a harrow.
Thanks for all the advice, I値l try to get some pics up later this week; supposed to rain down here tomorrow.
All I have is the box blade, gonna try and get it done with that.
/ Grading land with boxblade #12
You'll get it. Just have patience.
/ Grading land with boxblade #13
Yep, I know exactly what you are talking about. I've done the same thing on my land with a box blade and then a landscape rake after. I did mine with the rows so I wouldn't shake a kidney loose, then I worked them back and forth. Don't do it too wet, or too dry...
/ Grading land with boxblade #14
Yes, a box blade will work fine for that. I just did an abandoned garden for a customer, same except no rows, the hills and valleys were random and winding.
You won’t get golf course with a BB alone, but relatively flat and level is doable.
/ Grading land with boxblade #15
Yes you can do it. As others have said, it will take time. I would try two separate passes. First with scarifiers tearing it up, then with just the boxblade to see how I liked the result. Its old row crops so it shouldn’t offer too much resistance. Remember that is a 38 hp tractor and not a bulldozer. It can get the job done but it requires more finesse.
Don’t forget pictures.
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
2011 Altec CFD-1217 S/A Towable Brush Chipper (A61567)
2011 Altec...
New/Unused Landhonor Gas Powered Water Pump (A61166)
New/Unused...
2011 JOHN DEERE 544K WHEEL LOADER (A62129)
2011 JOHN DEERE...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61568)
2013 Freightliner...
New/Unused Quick Attach Pallet Fork Frame (A61166)
New/Unused Quick...
