B6100 fan belt replacement
/ B6100 fan belt replacement #1
mikehd
Kubota B6100-D
Hi all,
I've had our Kubota B6100DT since 1993 (bought used) and it has proven to be a reliable workhorse. I recall changing the fan belt in the early years of ownership and *think* that I did it without pulling the radiator. Time has come to change it once again (likely should have been a few years ago) and now I cannot imagine how I could have contorted myself to get to the tension adjustment bolt and then snake the belt up and over the fan with the tight clearances involved.
I've gone to kubotabooks and reviewed the relevant workshop repair manual (and my own copy I found) and there is no reference to this maintenance. I imagine it is too simple to include.
I suspect I'll drain the coolant, pull the radiator, and change the belt (and the hoses while I've got it apart), but for future reference, is there "that one secret" for changing the fan belt without pulling the radiator?
I found this site by searching for repairs to the 3PH (dropping with any load) and was very happy to see well written and documented descriptions of how to solve this issue. I was resigned to taking it to the repair shop but $5 later (two o-rings) its working better than when I bought it. So thanks to charlz for the write-up.
thanks everyone!
/ B6100 fan belt replacement #2
You can't just put the belt over the fan blades and work it around one or two blades at a time? There should be enough room between the fan and radiator.
Thanks for the reply. I think that is the only method other than pulling the radiator.
/ B6100 fan belt replacement #5
You might get some scraped knuckles but a lot faster........:)
/ B6100 fan belt replacement #7
Welcome to TBN.
I had a B7000 before which is basically the same, just one less cylinder.
While you have the belt out, check if the bearings on the fan/dynamo are good by just rotating it by hand and paying attention to any funny noises. I had mine go bad, luckily I caught it just in time before it failed catastrophically and damaged the radiator.
thanks ptsg, good to know what else to check.
/ B6100 fan belt replacement #9
If pulling the dynamo there is one bolt on it that you may have to bend a wrench to remove.
/ B6100 fan belt replacement #10
Good point.
I had to take the entire assembly out on mine because the neck for the radiator hose was all corroded.
I turned a piece of aluminium to replace it, but struggled to find a competent TIG welder. The one I found, did a piss poor job and I had to fill the voids with JB weld. I did enlarged the whole to the correct size in the end.
/ B6100 fan belt replacement #11
I think the belt tensioner tightens from the side. If you take off the side screen you should be able to reach it.
/ B6100 fan belt replacement #12
Just be glad it’s not a B20 with a front crankshaft driven hydraulic pump. Lots of wrenching to replace a fan belt.
Hi all,
Quick update: the fan belt is replaced, dynamo bearings were aok, and took about 2 hours going s l o w l y. I didn't have to disconnect the top radiator hose, but all the other steps were required.
Much thanks to all who chimed in with tips and especially the helpful video (thanks Thomas!) of another Kubota owner walking thru the sequence.
Cheers! :drink:
/ B6100 fan belt replacement #14
Want to know how to get belt off on a B6100d with front mount hydraulic pump.
/ B6100 fan belt replacement #15
Thata easy..cut it off..getting the new one back on is the issue.
/ B6100 fan belt replacement #16
John Deere TX Gator (A64912)
John Deere TX...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A64557)
1999 22ft Sea Ray...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
Case-IH P170 6 Cylinder Power Unit (A64912)
Case-IH P170 6...
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
PALLET OF MISC MOTORS AND PARTS (A68842)
PALLET OF MISC...
