What is Your Off Road -Ranch - Farm Utility Trailer
   / What is Your Off Road -Ranch - Farm Utility Trailer #11
I have a Wallenstein Timber Talon.
It comes with a Log Loader, Backhoe, and Post Hole Auger, and Dump Trailer.
I have added an upside down woodsplitter, feller-buncher, grader blade, seed spreader, etc.
They are expensive, but it take all the work off the tractor, and put it on the trailer making your tractor last so much longer. It also has its own engine so hours are also put on the log trailer instead. It makes a big difference because replacing a Kubota engine is $6000. Replacing that engine is $99.
Since it has its own engine, you can hitch it behind anything: pick-up, SUV, bulldozer, tractor, ATV, etc...
   / What is Your Off Road -Ranch - Farm Utility Trailer #12
What are you planning on hauling in it and what’s your budget, that would help us give you better ideas.
   / What is Your Off Road -Ranch - Farm Utility Trailer #13
Home made frame work with a box off another store bought trailer. Box is made to be removed, just in case. It also dumps by using a winch on the back of the ATV. I have some more pictures someplace but couldn't find them. If it is something you are interested in I will try to find the other pictures.
   / What is Your Off Road -Ranch - Farm Utility Trailer #14
This is my wagon. Incredibly versatile. IMG_0349.JPG. Country manufacturing, wooster ohio area. I fabbed and added the hydraulics. We haul a water tank, gravel, mulch, dirt, etc. 2 ton capacity and very stable.
   / What is Your Off Road -Ranch - Farm Utility Trailer #15
   / What is Your Off Road -Ranch - Farm Utility Trailer #16
This is my wagon. Incredibly versatile. View attachment 646293. Country manufacturing, wooster ohio area. I fabbed and added the hydraulics. We haul a water tank, gravel, mulch, dirt, etc. 2 ton capacity and very stable.
What did you do for the hydraulics? What size cylinder and how did you figure the geometry? I have a wagon from them as well, really like it, especially the 4 wheels so it can be detached easily.
   / What is Your Off Road -Ranch - Farm Utility Trailer #17
Just stuff around property, rocks and gravel, brush, cut wood, trash general purpose...Would like to stay around $300-500... Don't really need hydraulic dump...Keep in mind its small property and not industrial level use.... Probably will spend more hours under tree collecting leave than being used.... Would consider building if best material source were not 75 miles away and having to assemble a whole list of parts to get it done....
Dale
Wow like whole concept in picture, trailer and "rock" basket....
Dale
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
Dewalt D28499 7/9" Angle Grinder/Sander (A59076)
Dewalt D28499 7/9"...
FUEL CELL (A58214)
FUEL CELL (A58214)
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
