Kioti CK3510HST antifreeze?
/ Kioti CK3510HST antifreeze? #1
L47TLBwannabe
Manitoba, Canada
Kioti CK3510HSE
Recently I found my engine coolant quite low I couldn't find any leaks and no mixing in the oil. I was in the middle of a job after a snow storm so I topped it off with whatever I had what is the proper type that should be in these engines?
/ Kioti CK3510HST antifreeze? #2
The red stuff that is coming out now is compatible with the green and not as sweet.
/ Kioti CK3510HST antifreeze? #3
I use green 50/50 premixed in all of mine. My skidsteer uses coolant every time I blow snow so I keep antifreeze close by and top it off each time before I use it
Check the specs in your manual, of course.
What’s (was) the color of the antifreeze that was in there?
/ Kioti CK3510HST antifreeze? #4
yep, work machine really hard and it will puke to keep pressure under control and leaving a low level......
Recommend buying the 50/50 pre-mix of what ever color you have.
The overflow tank in mine was pretty nasty so, it was a good time to remove clean out and top off.
The gunk in the tank tells me this fall will flush with demin water and fill with 50/50 pre-mix of whatever my F-250 takes.
Observe the gunk build up in the overflow tank and see how well it performs...
Not a wet sleeve engine so cavitation not an issue.
/ Kioti CK3510HST antifreeze? #5
As mentioned, it's not a wet sleeve engine so you can use whatever you want. Just remember that certain antifreezes don't mix well. I've been using regular Prestone for the past 15 years. More important is to change it when needed. I do mine every 5 years.
Yeah I have Prestone pre-mix 50/50 I was fortunate I had some as did some servicing on my quad a while ago so I still had some in the jug. I didn't know it would blow out any antifreeze I ran a John Deere excavator a few years ago that would do that it was pretty frustrating we thought there was something wrong with it and then a mechanic told us 'its by design'. Thanks guys.
/ Kioti CK3510HST antifreeze? #7
Thanks for that. Now I know why mine was showing up low. I have 3 gallons just hanging around waiting to be used.
/ Kioti CK3510HST antifreeze? #8
There is a Youtube video somewhere, where a guy tests rubber coolant hoses vs silicone. He connected both types of hoses, filled with coolant and pressurized. He taped the process in a timelapse and it did show that the silicone hose is leaking fluid over time. Now during normal operation, it will evaporate and you don't even recognize it.
/ Kioti CK3510HST antifreeze? #9
Boy, would I like to hear the explanation on this process!
Cooling systems that are set up properly don't puke.
wish I was smart enough to splain it to you Lucy.....all I know is that when working the snot out of the machine coolant is all over the outside of the overflow tank collecting pasture clippings and dirt.....heh...so that's about as scientific as ah can gets....
oh and when the unit cools the level is low....maybe some shade tree engineer can splain it to the both of us in layman terms.....lol....
/ Kioti CK3510HST antifreeze? #10
Your either overfilling the system or your getting engine compression into the cooling system.
/ Kioti CK3510HST antifreeze? #11
YLee, does your expansion tank have a hose coming from the radiator to the bottom of the tank, and an overflow hose going from the top of the tank directed to the ground? Or does the tank just have a cap on it and the antifreeze overflows through the cap threads? A slot in the male threads of the tank, so the system breaths.
This is a pic of my CK 35 expansion tank. Just a cap. After getting tired of cleaning and filling the tank I went to my dealer and found that some tractors on the lot had a tank like mine and some had a overflow hose coming out of the tank neck.
I ended up letting the tank burp as much as it wanted till it no longer overflowed. It settled just a little bit above the minimum line and has been there for 5 years now.
/ Kioti CK3510HST antifreeze? #12
Not sure this explanation is simple, but just about every liquid expands when it's heated. I've always called it thermal expansion. Believe this is because the atoms and molecules are more "excited" and move around more at higher temperatures. This increases the distance between them, and the liquid "expands". The lower the temp, the less "excited" the atoms and molecules are, so they're closer together and makes the liquid denser. When your radiator is full and your thermal expansion tank is filled appropriately, you'll notice the tank always has a bit more room in it. That's to leave space for the coolant to expand. As the coolant warms up and expands, it will also increase the pressure on the radiator. Your radiator cap has a seal/spring on it that opens when the pressure exceeds the strength of the seal/spring, and allows coolant to flow into the expansion tank. This allows the pressure in the radiator to return to normal. This happens continuously when the engine is running. When you stop the engine and it cools down, the coolant in the radiator starts to contract and creates a vacuum. The vacuum pulls coolant from the expansion tank back into the radiator.
If you get too much thermal expansion or something else is pressurizing your cooling system, you'll have more coolant flow into the expansion tank than it can handle and it'll overflow. That's how you get your low fluid levels. That is, if you don't have a leak somewhere else.
You may want to check your radiator cap to see if it's working properly. It should maintain a certain amount of pressure on the cooling system to keep the boiling point of the coolant higher. If it's weak, it may not be keeping pressure, and letting more coolant flow into the expansion tank than it should.
I know that's not terribly simple, but that's basically what happens...at least from my understanding!
/ Kioti CK3510HST antifreeze? #13
Last August cut about 8 acres of an elderly rancher's place. The old cattle pen veggie was to the top of rear tires and the open graze area was about halfway up the rear tire. On the second day the temp gauge went past the normal op. indication. Let it cool off and then went back to work. by day's end indication moved towards the red zone again.
When offloaded at home the tank level was below the minimum line and the tank was covered with debris caked to the tank.
So that's what I based my comment on. (note, yeah forgot to take blower to keep radiator clean)
So mine has the radiator overflow hose to the cap and a second overflow to the ground.
The tanks look clean (well sorta) since I hosed it down hard after a cutting session.
You can see how it collects dirt/dust as coolant seeps around the cap. I thought it was normal since it's been that way since day one.
level is about an inch from the full line indicator.
Have not been able to work it hard enough to see it lose any level, yet.
Should close the loop with this.
/ Kioti CK3510HST antifreeze? #14
I just wonder if the overflow tank is just to small for the fluid expansion contained in the engine and radiator. I need to compare the fluid quantities between the tractor and my truck which has a tank that's at least 6 times the size. Just a thought as to why my tank might end up almost empty after a good workout.
/ Kioti CK3510HST antifreeze? #15
Vic, with the tank I have there is a sponge under the cap that stays moist with all the sloshing around on my property. The pressure differential between the tank and atmosphere will push the fluid in the sponge out the slots in the tank threads. I think maybe a baffle in the tank would reduce this.
It is possible the tank is to small, though myself, I have never seen the level above the max mark when very hot after extended use.
Glad to see some of the chrome hood lettering CKs still going.
/ Kioti CK3510HST antifreeze? #16
The one coolant I have been using for years in my TDI is sierra antifreeze. I ran it for two timing belt changes at 100% no water I added 2-3oz of water wetter the year I decided to keep the grill completely blocked only left the inter cooler uncovered. I'm still running 100% but no water wetter (it did make a difference in temps) just never added it and I have only kept the top blocked.
The nice thing about sierra antifreeze is it is non-toxic. They sell it at Ace hardware by me.
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
2025 JBD 32in. Hydraulic Mixing Bucket Mini Skid Steer Attachment (A61567)
2025 JBD 32in...
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
2003 Sterling L8500 Series FEC 3216 8 Ton Knuckle Boom Crane Truck (A61568)
2003 Sterling...
2017 PETRBILT 389 6X4  T/A SLEEPER TRUCK TRACTOR (A59908)
2017 PETRBILT 389...
New Holland Workmaster 75 Tractor (A61166)
New Holland...
