Kioti CK3510HST antifreeze?
   / Kioti CK3510HST antifreeze? #1
L47TLBwannabe
Manitoba, Canada
Kioti CK3510HSE
Recently I found my engine coolant quite low I couldn't find any leaks and no mixing in the oil. I was in the middle of a job after a snow storm so I topped it off with whatever I had what is the proper type that should be in these engines?
   / Kioti CK3510HST antifreeze? #2
The red stuff that is coming out now is compatible with the green and not as sweet.
   / Kioti CK3510HST antifreeze? #3
I use green 50/50 premixed in all of mine. My skidsteer uses coolant every time I blow snow so I keep antifreeze close by and top it off each time before I use it
Check the specs in your manual, of course.
What’s (was) the color of the antifreeze that was in there?
   / Kioti CK3510HST antifreeze? #4
yep, work machine really hard and it will puke to keep pressure under control and leaving a low level......
Recommend buying the 50/50 pre-mix of what ever color you have.
The overflow tank in mine was pretty nasty so, it was a good time to remove clean out and top off.
The gunk in the tank tells me this fall will flush with demin water and fill with 50/50 pre-mix of whatever my F-250 takes.
Observe the gunk build up in the overflow tank and see how well it performs...
Not a wet sleeve engine so cavitation not an issue.
   / Kioti CK3510HST antifreeze? #5
As mentioned, it's not a wet sleeve engine so you can use whatever you want. Just remember that certain antifreezes don't mix well. I've been using regular Prestone for the past 15 years. More important is to change it when needed. I do mine every 5 years.
Yeah I have Prestone pre-mix 50/50 I was fortunate I had some as did some servicing on my quad a while ago so I still had some in the jug. I didn't know it would blow out any antifreeze I ran a John Deere excavator a few years ago that would do that it was pretty frustrating we thought there was something wrong with it and then a mechanic told us 'its by design'. Thanks guys.
   / Kioti CK3510HST antifreeze? #7
Thanks for that. Now I know why mine was showing up low. I have 3 gallons just hanging around waiting to be used.
   / Kioti CK3510HST antifreeze? #8
There is a Youtube video somewhere, where a guy tests rubber coolant hoses vs silicone. He connected both types of hoses, filled with coolant and pressurized. He taped the process in a timelapse and it did show that the silicone hose is leaking fluid over time. Now during normal operation, it will evaporate and you don't even recognize it.
   / Kioti CK3510HST antifreeze? #9
Boy, would I like to hear the explanation on this process!
Cooling systems that are set up properly don't puke.
wish I was smart enough to splain it to you Lucy.....all I know is that when working the snot out of the machine coolant is all over the outside of the overflow tank collecting pasture clippings and dirt.....heh...so that's about as scientific as ah can gets....
oh and when the unit cools the level is low....maybe some shade tree engineer can splain it to the both of us in layman terms.....lol....
   / Kioti CK3510HST antifreeze? #10
Your either overfilling the system or your getting engine compression into the cooling system.
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2023 JOHN DEERE 2032R LOT NUMBER 164 (A53084)
2023 JOHN DEERE...
2018 John Deere 8270R MFWD Tractor (A53342)
2018 John Deere...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2019 TAKEUCHI TL12V2 SKID STEER (A51246)
2019 TAKEUCHI...
UNUSED GREAT BEAR 78" HEAVY GRASS FORK GRAPPLE (A51248)
UNUSED GREAT BEAR...
