Must Have Shop Items
/ Must Have Shop Items #161
Could be a replacement for the first aide kit..... :)
Yes and video surveillance. And now we have to add dog food and treats.
/ Must Have Shop Items #163
/ Must Have Shop Items #165
So. We need to add SHOP DOG to the list.
You could be right. Our Beagle can even sniff out a bruise and thinks it is his duty to take care of the boo boo.
/ Must Have Shop Items #166
When I wired my 220V Air Compressor I ran it thru this contactor. When I turn on my shop lights the Compressor has power. Turn the lights off and the Compressor is disconnected.
/ Must Have Shop Items #167
I just made sure I had no air leaks. No leaks/ no run.
/ Must Have Shop Items #168
Yeah, I don't have any leaks either.
Good friend of mine left his on all the time. Line busted in the middle of the night. Compressor ran until it caught on fire. Was awakened by a neighbor saying his shop was on fire. He was able to crawl in on his belly and hook a chain to his Grandpa's 1970 Cadillac that he had just finished restoring. Lost everything else.
/ Must Have Shop Items #170
Good plan.
I'd like to take credit, but actually the Electrical Supply store where I got all my stuff suggested it when I asked about some type of disconnect. :)
/ Must Have Shop Items #171
I really like the idea of lights off/compressor off... gonna have to think how I can do this simply/safely.
/ Must Have Shop Items #172
Mark, I think I paid $40 for the contactor, another $10 for the box. The box is between the power source (fuse box) and the compressor. Then add a circuit from the nearest light to the box. All of that was pretty simple for me since the compressor is in the bathroom and so is the fuse box. The light circuit was about 20ft away.
/ Must Have Shop Items #174
Oh, good point! Thanks for that. Never thought of a fire.
/ Must Have Shop Items #175
I'm envious of everybody with a shop.
Well, get with the program. In Alaska, a Shop is a necessity. It took me some 25 years of working in the ice, snow, rain,mud and gravel to finally get fed up enough and build one. Sure makes life easier.
/ Must Have Shop Items #176
I built my first shop after my Eldest Son was grown and had left home. 2nd Son was a Senior in HS. 3rd Son was a Freshman.
I waited too long. I should have built it 10 years earlier and shared it with my Sons.
If you would use a shop, build it now, by whatever means is needed. Especially if you have kids at home.
/ Must Have Shop Items #177
I was thinking about doing something similar to your idea about 10 years ago. But instead I opted for a switch and pilot light combo right besides the man door. When switch is on so is a green pilot light. This reminds me to turn it off before leaving.....had all the parts in stock.
/ Must Have Shop Items #178
How did you wire it? Did you use a contactor to handle the 220V, triggered by a 110V toggle switch?
/ Must Have Shop Items #180
A Shop is also good for a Marriage. A little distance between you on occasion can be a good thing.
2016 Freightliner Columbia 120 Glider Day Cab Truck, VIN # 3ALXA7CG9GDGZ6492 (A61165)
2016 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
UNUSED WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A62131)
UNUSED WOLVERINE...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
