Good morning!!!!
   / Good morning!!!! #108,141
"I decided to clean the north side of my metal barn today. I did not want to use a bleach solution, for fear of accelerating rust. So I just mixed some simple green with some water and sprayed it on. It helped, but not nearly as efficient as the Jomax/Bleach solution. My arms got tired from all the pressure washing up high on the ladder."
Have you ever tried Wet & Forget Kyle? No rinsing, no bleach. It doesn't work fast but, does keep surfaces clean for a long time.
I use it with my pressure washer foam gun.
I'll bet it works good. Make sure you cover up well when spraying it. That's some pretty tough stuff. Here is the SDS sheet.
https://www.wetandforget.com/downloads/SDS_USA_Wet_Forget_9.9_12282019.pdf
Here is the active ingredient:
Akyld Dimethylbenzylammonium chloride
I believe it to be quite corrosive, but I will defer to any chemical peeps out there.
Need to make a quick run to Walmart.
BEF, I'm finding out that many, many have read it.
Don's rumor may be correct, Austin has verified 2 people with the virus.
   / Good morning!!!! #108,142
   / Good morning!!!! #108,143
Spray it on but, DO NOT rinse it off. The W&F has a residual effect. In a pump up sprayer mix it 1 part W&F to 5 parts water.
I use my PW Foam gun to treat 2nd story from the ground.
MATCC Foam Wash Gun 3000 PSI High Pressure Washer Jet Snow Foam Lance Foam Cannon Foam Blaster with 3/8" Connector Amazon.com: MATCC Foam Wash Gun 3 PSI High Pressure Washer Jet Snow Foam Lance Foam Cannon Foam Blaster with 3/8" Connector: Automotive
It has variable ratio and pattern control
I'm a happy user of W&F, too. Bought a 2 pack at Costco a year or so ago.
   / Good morning!!!! #108,144
If I recall when WWII started we as a country were ill prepared. When Japan bombed Pearl Harbor one out our lowest points. In less than four years we were a manufacturing giant. We are in a serious battle with this virus my bet is with everyone working for a common goal we will rise from this even stronger than before. But we must work together. Enough of my soap box
   / Good morning!!!! #108,145
Read #12 , if you have a pond or birds nearby.
   / Good morning!!!! #108,146
Dr. Siegel gave a Covid 19 update this morning...good news vs. other info I had heard. C19 can live on:
- plastics - 2 to 3 days
- wood - 1 day
- metal - 3 to 4 hours
But it only remains viable (able to infect you) for about 8 hours.
Humidity and UV sunlight, as we get in summer helps since the humidity helps your membranes protect, and sunlight helps kill virus.
   / Good morning!!!! #108,147
- wood - 1 day
Many folks suffer from allergies this time of year, with similar symptoms, which could put extra pressure on medical facilities .
   / Good morning!!!! #108,148
Thanks for sharing wngsprd
   / Good morning!!!! #108,149
Agree Rick
   / Good morning!!!! #108,151
History teaches us that men and nations behave wisely once they have exhausted all other alternatives.
Abba Eban
Diplomat
   / Good morning!!!! #108,152
Very wise words riptides
It is about to quit raining here shower time and go get zturn from repair shop pick up sticks
   / Good morning!!!! #108,153
Good point, Rick. The orchards are blooming out here, and I'm sneezing and coughing like crazy. I've been using that as an excuse for not shaking hands, saying "I'd shake your hand but I'm just getting over a cold." Yesterday's trucker appreciated that...
Hope the men in white jackets don't cart me away as a possible CoVid-19 vector!:laughing::shocked:
   / Good morning!!!! #108,155
My son in law loves it, I have not used it but I am willing to try it. On my house and buildings I use bleach 1/8 with water in a low pressure sprayer, perfectly clean in about five minutes, no need to rinse and you don稚 blast siding and shingles with high pressure. My poor pressure washer sits a lot the last ten years or so since I discovered my system.
   / Good morning!!!! #108,156
I am a bottle of bleach user. Everything we have is white so that makes it easy. I usually wait until mid summer, the hotter the better, spray and walk.
Use my pump sprayer for those higher hard to reach areas.
   / Good morning!!!! #108,157
I have a stockpile of leaves and moss.
Good to know moss can be used as toilet paper, we have plenty growing on the roof.
Any tips for climbing the ladder with jeans around ankles ? :confused2:
   / Good morning!!!! #108,158
As promised...
WARNING! This video is not safe for viewing by gravel addicts!:laughing:
Ok I'll bring extra TP for some seat time to tackle that load!
Good morning! 69˚F golfers in shorts this morning heading to the 80s. Had my green/yellow/blue oatmeal this morning to ward off the virus. (Kale/turmeric/blueberries)
Trail blazers this afternoon.
   / Good morning!!!! #108,159
Get the moss in hand *before* the need arises. That's my last tip of the day.
TANK MANIFOLD (A55745)
Year: 2012 Make: GMC Model: Acadia Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 188,471 Plate: (A59231)
Year: 2012 Make...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
2020 SAVANA 3500 16FT BOX TRUCK (A59905)
2020 SAVANA 3500...
