Has anyone put triple rear remotes on your LS with cab? I need help
   / Has anyone put triple rear remotes on your LS with cab? I need help
The remotes are finally on but no thanks to LS. Don't depend on them to furnish installation instructions for the triple remote kit, you are on your own. 2 of the steel lines had to be reshaped also so don't rely on them to send you the correctly formed hydraulic lines either. I am going to try to attach a picture. This installation is on a NH Boomer 55 which is the same tractor as the LS 4155XR
   / Has anyone put triple rear remotes on your LS with cab? I need help #12
I’m curious? Did you consider just buying an XR4155? My XR4155HC came with 3 remotes. Not sure why you’re beating up on LS when you bought a New Holland?
I’ve yet to see a NH Boomer less expensive than it’s LS counterpart.
   / Has anyone put triple rear remotes on your LS with cab? I need help #13
I’m glad to see that you managed to install the triple remote kit on your New Holland. The new model that replaced the 4155 also comes with only 2 remotes installed from the factory so I was asking a LS dealer about getting it with three remotes and he seemed pretty reluctant to attempt it. So I wound up buying a leftover 4155 from a different dealer mostly because I wanted the three remotes.
   / Has anyone put triple rear remotes on your LS with cab? I need help #14
My MT3.57 came with 3 remotes.
   / Has anyone put triple rear remotes on your LS with cab? I need help #15
I suspect these manufacturers and dealers hold some of this information close to their chest for obvious reasons. Most of these types of upgrades are dealer installed options. What strikes me out of all of this is that NH doesn't offer a 3 remote option. That perplexes me. Almost any tractor you buy can be bought with triple remotes and some sort of third function up front.
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2011 VOLVO VNL760 SLEEPER (A59904)
2011 VOLVO VNL760...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2007 Ford F-150 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
TANK MANIFOLD (A58214)
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
