What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #1,091
It's been my experience that it takes longer to cool down. For example, a 80 degree day mowing for hours will take mine about 5 minutes to cool down. That is parked with the AC off. The other day it was 1ーF and it took about 1.5 minutes to cool.
I monitor the EGT probe through the obd port and I look for 350 degrees or less before I shut it off. So if you don't have a gauge I'd suggest letting it cool a bit longer.
What device do you use to monitor the live engine data?
I think I've burned more diesel in the last 2-3 days than I have in the last 2-3 months. Digging stuff, pushing stuff around, breaking dirt with the middle buster, dragging stuff with the landscape rake. Ground is still wet enough to slip tires under load in some places, but at least water isn't running across the surface and filling holes as fast as they appear.
   / What did you do on or to your LS Tractor today? #1,094
   / What did you do on or to your LS Tractor today? #1,096
Tractor time
Needed some fork extensions this morning. Perhaps more the economy model
Still, quite effective
And very functional for placing my roof structure
No metal yet, tomorrow is another day
Whatever works sometimes right!
I have some leftover rectangle tubing that is like 6 ft long and fits over my forks i use occasionally i need to drill and tap them so they dont slide off nutnever seem to do it when im not busy lol
I'll turn over 200 hours in the next few days, at 196.4 now. Picked it up in September of '18, so a year and a half or so.
What does a 26 x 12.0 – 12 R4 tire mounted to the wheel and filled with Rimguard weigh?
   / What did you do on or to your LS Tractor today? #1,099
   / What did you do on or to your LS Tractor today? #1,100
Building more burn piles.
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
500BBL WHEELED...
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
2017 BOBCAT T770 SKID STEER (A52709)
2017 BOBCAT T770...
1985 Ford Ltl9000 Tender Truck (A56435)
1985 Ford Ltl9000...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
