TnAndy
- Joined
- Aug 9, 2013
- Messages
- 2,000
- Location
- East Tennessee
- Tractor
- Yanmar LX410...IHI 35J excavator Woodmizer LT40
Ok....I bought one of the Saw Haul chainsaw carrier and mounted it to the left side FEL post about 8-10 months back. Well, it became useless today. It depends on the scabbard to hold it in position, and the scabbard PLUS the plastic insert that holds the scabbard in the metal frame are made of fairly thin plastic, and the dog on my Husky simply chewed thru them.
So then the scabbard flops around and can fall out the bottom, then the saw flops around as well, like this:
Here is how the top flange of the scabbard looks, you can see where the dog of my saw has chewed thru the thin plastic flange....and the flange is only on the outboard side. If you're not familiar with these, the scabbard simply slides down in the other plastic insert piece and ALL that holds it is that little flange. (2nd pic)
They probably sell a replacement scabbard.....but less than a year's life out of them ? Really ?
With the scabbard removed, this photo is the plastic insert that goes in the rectangle of metal that bolts to the loader post. It is also chewed up by the saw dog and needs replacing. So DID THEY MEAN FOR IT TO BE REPLACED ?? Apparently not, since you have to drill out the two rivets holding it in !
Pair of needle nose to hold the spinning rivet, then rather than take the whole bracket off the post, I ran the drill bit on thru the metal bracket and drilled the other rivet out from the back side of the rivet.
Insert removed from metal bracket......note how thin the plastic is....
My fix:
2 scraps of 5/8" plywood, 4-1/4x4" bolts (3 1/2" would be better, but I didn't have them handy), 4 nylon insert lock nuts and some washers. Pre-drill holes, sandwich on top the metal bracket so you have a fairly sturdy bottom piece to HOLD THE DADGUM SAW from flopping around. Fire up the saw and plunge cut down thru both pieces ( or use a router if you want fancy), and you're back in business. 1/2 hour fix....and forget the fool scabbard.
Let's me finish by saying I'm way less than impressed with Saw Haul. Likely if you don't haul a REAL SAW in it, they would last longer....but I wouldn't even bet on that.
My fix:
![IMG_0335[1].JPG IMG_0335[1].JPG](https://www.tractorbynet.com/forums/data/attachments/552/552970-b88759a4e55394740a451ed1eab8c3df.jpg)
![IMG_0338[1].JPG IMG_0338[1].JPG](https://www.tractorbynet.com/forums/data/attachments/552/552959-2b8b581ea8cd22576ac3862d28898f27.jpg)
![IMG_1174[1].JPG IMG_1174[1].JPG](https://www.tractorbynet.com/forums/data/attachments/552/552954-39664a74bf637412dcdbbe09f96561db.jpg)
![IMG_1175[1].JPG IMG_1175[1].JPG](https://www.tractorbynet.com/forums/data/attachments/552/552967-779d08749a6a4b39b22be0c271ec03e4.jpg)
![IMG_1419[1].JPG IMG_1419[1].JPG](https://www.tractorbynet.com/forums/data/attachments/546/546626-637ef17f9d6cda811019e09c1193db18.jpg)
