Car lift problem
/ Car lift problem #1
leveled
Gold Member
NY
MX5100HST FEL, KX121 MINI X GEHL 6640 Ferris IS3200z Kubota 1100RTV
I have a issue with my car lift. It will not raise or start up, with a load on the it. I have checked voltage 220 plus... and the capacitors on the electric motor . I had no power at the start capacitor on start up, so I assumed the contacts going to the start switch or the centrifugal switch were bad. I took the motor in for service and they told me the internal switch was bad. I had them repair it for about 115 bucks.
I have now reinstalled the motor on the pump and still have the same problem, I check voltage again and it seems to be correct, I even bypassed the electromagnetic switch by using the breaker as a temporary switch. The lift will operate if is lowered completely to the ground or if i use the lowering handle as a temporary pressure buffer.
I am at a stand still waiting on a service tech for the manufacture of the 4 post lift, I feel it may be a restriction in the pump of some sort. I have already followed up with the electric motor shop and they have said it must be on my end.
Anyone have a idea what it could be?
Thank you
/ Car lift problem #2
My first guess would be that there is a check valve on the high pressure output of the hydraulic pump which has failed and is causing there to be back pressure on the hydraulic pump when it goes to startup.
Can you post a picture of the hydraulic pump and the lines going from it to the valve then back to the tank?
Aaron Z
/ Car lift problem #3
Aaron Z
Ditto- sounds like the motor won’t go with full pressure against it. But as soon as you bleed pressure it works. I assume their is some sort of relief to allow the motor to start before it gets hit with full pressure. Air compressors, refrigerators,AC pump etc all relieve pressure to allow the electric motor to start.
/ Car lift problem #4
Thank you
If I remember correctly my dads did the same thing and it turned out to be a safety switch was bad-his had a safety switch that kept you from going to high. Im assuming you had the same type of car lift but we dont know.
/ Car lift problem
Thanks for the reply's the lift is a Bendpak 4 post lift.
/ Car lift problem
No safety switch because it is a 4 post lift. In the magnet switch it is bypassed. The cables just max out.
/ Car lift problem #7
Some of these motor/pumps were know to have the pump coupler go bad. You could have inspected it when you pulled the motor off the pump. There should have been a splined coupler in there.
Not really sure what your issue is. It sounds like the motor is running but not building pressure. There is a relief valve on the side of the AL block but could also be a bad pump.
/ Car lift problem
The shaft was fine, and the motor is not running, it wont start with the lift loaded. It will run when it is in the lower position or when I use the handle to release pressure.
/ Car lift problem #9
Did they replace the capacitor when they replaced the switch?
/ Car lift problem
No they tested it, and said it is fine. I was thinking of retesting it.
/ Car lift problem #11
They are usually cheap.
It just sounds like the motor doesn't have enough power to start up with the hydraulic load. If you were closer I have a spare motor sitting in my garage.
/ Car lift problem
I tested the capacitor and it test out to be correct. i did also try in the beginning with a different capacitor that i had bought on amazon, and it did not work, although it was dented when i got it.:) I sent it back.... that is when i decided to take the motor in. Thanks for the offer on the motor, this group is great i have been a member since 2008.
/ Car lift problem #13
Thank you
Compare voltage with the motor off, and with the motor powered. There should be no more than a few volts difference.
Can you measure the amperage if the motor is started? A motor that is powered but is blocked should take up to 8 times the FLA (normal full load amperage which you find on the name plate ).
If voltage drops on the motor leads, than you have a problem in the "feed".
If the amperage goes up, up to 8 times FLA and the motor will not start running, than the problem is mechanical or hydraulic.
A simple test: If the motor has cooling fins on the end, try if you can turn them with a screw driver through the openings. If you cannot, than the motor cannot start to run.
/ Car lift problem #14
Good stuff Bert.
And maybe uncouple the pump from the motor and see if it will start??
/ Car lift problem
Volts
Off 240 Volts
Running but stuck 223 Volts
Amps
12 (when running) one lead (lift works for ground position)
60 (when stuck each) one lead
/ Car lift problem
Good stuff Bert.
I am waiting on the manufacture to respond, its been 1.5 days they said 24 to 48 hours. Hopefully they can give me a parts diagram of the pump, then I will take it apart again. Its a pain to pull the reservoir off since it has no drain plug.
/ Car lift problem #17
have you called bendpac? they deal with these daily.
/ Car lift problem #18
Yep. Had mine apart a few years ago.
/ Car lift problem #19
Volts
Off 240 Volts
Amps
12 when running each lead (lift works for ground position)
60 when stuck each lead
The motor seems OK. Do not try to run the motor for more then 2 seconds if it will not start. There is no thermal shut off.
60Amps by 230Volts generates more than 10.000 Watts in heat in a blocked motor! ( 30.000 BTU per hr.)
If the motor runs OK when you hold the hydraulic lever in the "lower" position, than the pump should be OK. Check the hose to the cylinder for pinched or kinks, check steel cables, sheaves, and other mechanical. It looks to me that something is preventing the oil to flow to the cylinder or something prevents the cylinder from extending.
/ Car lift problem #20
I took his posts to refer that the lift works fine if he starts it with it completely down or if he pushes the down lever as he starts it???
UNUSED RAYTREE RJSG30-30" TRANSVERSE STUMP GRINDER (A62131)
UNUSED RAYTREE...
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
2006 Ford F-550 Flatbed Truck, VIN # 1FDAF57PX6EB82087 (A61165)
2006 Ford F-550...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
20ft 2-Door Shipping Container (A61567)
20ft 2-Door...
Ford Pickup Truck Bed (A61568)
Ford Pickup Truck...
