DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,678
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
I'm wondering if anyone here, has sown Renovation Clover Renovation | White Clover on their hay ground, and how it performed. I wanted to sow a legume in my stand of hay, along with a bit of Alfalfa at a low percentage, yet enough to put some nitrogen in the ground, to help feed the Fescue, and Rye Grass. This hay is for horses, so don't want it to hot.
Reading several application rates, anywhere from the companies web site several college Extension offices. Most say 2-3 lbs. per acre in a mixed, existing stand. I figured 1-1/2-to 2 lbs would be about right.
I picked up my various seeds today, as they will be frost seeded by broadcasting mid-Feb, through mid-March. The seed dealer warned me to only sow, not more than 1 lb. to the acre. A higher amount, and in can become invasive, and choke out other grasses. So, I'll take his word for it, and see what happens. I'll give it 2 years, and see what it does. He said the seed viability should be 3-5 years, so I'll have enough to re-seed if something should happen to this planting.
Just wanted to ask, or forewarn others if you plan to use it, on what he said about the seeding rate. And, if others have planted it, at what rate did you sow it, and what were the results. From what I've read, real experimentation with it started in approx. '09, so maybe a few have tried it.
On the bright side, I have so many Deer grazing in the hay field at night, it may help keep it under control.
