Floating Anvils...
/ Floating Anvils... #21
I find a lot of the comments on this almost humorus,
I spent many years in the instrumentation and control field,
one project back in the 80's early 90's was the removal from service of numerous differential pressure meters both recorders and transmitters,
that employed mercury filled bellows as sensing elements and many of them came out of water systems. Prior to removing them they had required being flushed and cleaned because the operators would not operate the valving correctly and would blow the mercury out and into the process fluid. We used to routinely clean and reuse the mercury in those meters and then add to it during calibration and servicing. When we took those meters out of service we recovered hundred of pounds of mercury.
Also many of our manometers were mercury filled, some were scaled in inchs of hg many had conversion scales on them to read in inches of water using mercury as a fill fluid.
When all the OSHA mercury exposure standards got shoved down our throats $100,000 of dollars of calibration standards and labs and shops had to be trashed and sent of to haz mat land fills.
/ Floating Anvils... #24
Mercury is extracted from Cinnabar ore by heating it to a high temperature. Not a good occupation standing over a smelting furnace.
Funny thing, I had a science teacher in 1967 who had the baby food jar full of mercury to pass around the class so we could stick our fingers in it and coat pennies with it.
He suggested we cut the ends off flourescent tubes to collect it if we wanted to have some at home.
He spent lots of time typing up lab experiments while chain smoking Tareytons in the back of the classroom, taught us how to make fireworks, testing them on a cable that stretched from the back porch to the baseball backstop 300 ft downrange.
It didn't seem to hurt him any, he died at 92 some years back.
ya, but if he didn’t play with mercury he might of lived to be 105...... actually I played with it when I was a kid. It never hurt me any.
I played with it when I was a kid, it never hurt me any. I played with it.......
/ Floating Anvils... #26
Moss, did you realize Mercury was in retrograde for the first time in 2020, starting the day before you posted this? ;)
/ Floating Anvils... #27
Just to add some actual facts to the mercury discussion. Mercury in its LIQUID form is fairly innocuous. A spill in a house, if not cleaned up, will slowly evaporate adding mercury vapor to the atmosphere. That is what is dangerous. One can swallow liquid mercury and it passes out of the system
https://www.michigan.gov/documents/mdch_MercurySpillFactsheet_85689_7.pdf
The normal air changes in a house would keep the levels low unless someone was trying to bump it up.
Just more bureaucratic paperwork.
/ Floating Anvils... #28
That depends on how "tight" the house is.
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
(INOP) 2011 FORD F-150 XL SINGLE CAB TRUCK (A59823)
(INOP) 2011 FORD...
New Holland EC215 (A60462)
New Holland EC215...
Kubota B2301 (A53317)
