Box blade shanks
/ Box blade shanks #1
AllByteNoBark
Gold Member
South Texas
Kubota L3560HSTC LE, John Deere 950
Can anyone tell me if box blade shanks with rear slots will work on a box blade that came with shanks with front slots? Having trouble finding reasonable priced shanks.
/ Box blade shanks #2
Pictures needed. How were the shanks held in place?
/ Box blade shanks
That is part of the issue I have never had any shanks. I bought the BB used and it did not have any.
I will call the dealer I use for attachments and see how much they are there. They have been pretty good on some items.
The bar is a 4 in square tube with a 3/4 x 2 1/2 in holes
/ Box blade shanks #5
My used BB came without scarifiers so I called the mfgr to price them out,
My blade takes 7 of them at $57 ea. and 3 retainers at $15 ea. plus freight.:eek:
/ Box blade shanks #6
I found them to be least expensive at Agri-Supply.
/ Box blade shanks #8
OP they should work. You my need to move the retaining pin to the front. I think the most common one's are center hole or front slot though.
/ Box blade shanks #9
Im not sure.
I went to a steel fab shop and they made me some and spot welded teeth on them for less than buying online or at a store. IMG_1212.JPG
/ Box blade shanks
I'm thinking they will work. Will probably end up trying them. The ones I was looking at are gone but am guessing they will have some more.
/ Box blade shanks #12
I guess I got lucky. I was at my LS dealer (about 10 years ago) and saw a pile of scarifiers laying by the door. Asked if they were for sale and how much, the owner said $5 each so I bought 4. Still have a couple left. They are easy to bend and break with my LS P7010 if using it in 4 WD. I find I do less damage to the teeth if I just use 2 WD. I do like those shop made ones, they look much thicker and stronger than the ones I have.
/ Box blade shanks #13
Quality Farm Supply has shanks with front slots for $30. Don't know how many you need, but they have flat-rate shipping of $9.00 on orders under $200; free if over $200.
https://qualityfarmsupply.com/product/BUCKET-TEETH-ampersand-EDGES/BOX-BLADE-SHANKS-ampersand-POINTS/Shanks/873-dash-103110
/ Box blade shanks #14
Make sure the length is right and the notch spacing will fit the frame of the box blade.
/ Box blade shanks
Thanks that is the best deal I've seen. The BB is a Modern so they should fit. Need 6 of them for a full set. May watch CL for a while before ordering them. Have plenty to do.
/ Box blade shanks
Decided to go ahead and order 6 of the shanks and clips to go with them. Looks like just what I need. Thanks again for the recommendation!
1990 CASE 580K LOADER BACKHOE (A64047)
1990 CASE 580K...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2015 John Deere 8345RT Track Tractor (A63109)
2015 John Deere...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
2014 Nissan Frontier Ext Cab Pickup Truck (A61573)
2014 Nissan...
