question about bush hogs
/ question about bush hogs #1
BIKER BOB
Raymond, Maine
Mahindra 3215
I hear people speak of "stump jumpers" when bush hogs are talked about. What is the stump jumper? Is it the hub that holds the blades or is a brush hog considered a stump jumper?
Probably a rookie question but I just don't know.
Thanks
/ question about bush hogs #2
Stump jumpers are typically circular metal pieces located just above the swinging bush hog blades. A stump will hit that rather than try to stab a hole through the top of your bush hog housing.
If you have a choice, try to get a bush hog where the stump jumper stays in place when you remove the bush hog blades for sharpening. This was not the case on the JD LX4 but is the case on the Frontier 4' bush hog that I now have.
Ralph
/ question about bush hogs #3
Here's one.
Some cutters don't have the circular pan, just the bar to mount the swinging blades.
Bruce
Thanx for clearing that up for me! Makes sense
/ question about bush hogs #5
Ralph
Sure not going to say the reason for the stump jumper is not what you are saying and no doubt it would help with what you said but I always though that was so the cutter would ride up and over a stump or "jump the stump" rather than straight arms hitting a solid stump damaging a gear box. It no doubt does both.
/ question about bush hogs #6
Here is the stump jumper on my 7' brush hog, with the sun shining on it:
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2019 Freightliner M2 106 26ft. Box Truck (A61568)
2019 Freightliner...
2015 FREIGHTLINER CASCADIA ROAD TRACTOR (A62130)
2015 FREIGHTLINER...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
Mini Skid Steer (A60352)
Mini Skid Steer...
