Quick Attach mounting plate
/ Quick Attach mounting plate #1
abunchofidiots
Mt. Sidney, VA
Yanmar YT 235
There seems to be a large variance in the dimensions of quick attach plates. Most show the width needing to be 44 to 45 inches. The vertical seems to vary wildly from 15 to 18 inches. Being an ISO standard, I'm surprised it is not described better.
/ Quick Attach mounting plate #2
I would think the distance between the top slot and the lower pin slots is the critical dimension regardless of the OA size of the plate.
/ Quick Attach mounting plate #3
If you're talking about skid steer quick attach plates I have purchased two from different vendors on Ebay and they both fit fine. They are two different thicknesses.
/ Quick Attach mounting plate #4
I have ordered 3 SSQA plates through Ebay, purchased a set of pallet forks, and borrowed the forks and buckets off our skid steers at work and all fit my tractor fine.
Never seen or ran into an issue with different height SSQA plates.
KUBOTA MX5800 TRACTOR (A62130)
KUBOTA MX5800...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
