loader joystick mod
/ loader joystick mod #1
GeneV
Elite Member
Lake County, IL
Bradley 48" stander MF GC1710
I wasn't happy with having to lean forward to operate the loader joystick. A little bit ago, I heated it up with a torch and bent it so it would be closer, but it was still farther out than I wanted it.
So, I bought a Volkswagon gearshift extension on Amazon for $10, installed it today. It turned out pretty good, very comfortable now.
/ loader joystick mod #2
Great looking job! Can really make it more user friendly.
Thanks! We're supposed to get some snow on thursday, so field test on the way.
/ loader joystick mod #5
Looks good! I had the same problem... having to lean forward to grab the lever. I also extended mine about 7 inches. Works great now! You will also find that it helps to feather the control much easier!
Post a pic, let's see it man! I'm sure you and me ain't the only ones who needed this mod.
/ loader joystick mod #7
First pic Is the stock one, the next pics are of the longer one I made. The stock one was threaded 10mm. I could not find any 10mm threaded rod, so went to TSC, got two 10mm bolts and cut the heads off. I stuck the bolts in the ends of 3/8 tube steel, did a quick tack weld, and threaded it on the valve. The stock knob went on the other end. Took longer for the paint to dry than make the thing!
Cool, nice that the joystick threads on, gives you some options. Mines just one piece going all the way to the valve.
Per your sig, I take it you're a medic? I was an emt-p in the previous century.
/ loader joystick mod #9
Yep, I was a EMT-P back in Philly years ago, gave it up for a while (well at least not professional). About 13 years ago, went back to school and got a degree in EMS as a medic. Been working in a high volume system (130k calls / yr) for the last 12 years, until I got hurt on the job last year. The Docs say I can never return to the streets. Waiting any day now to be scheduled for a third surgery next month..... probably the end of my career. Even so, I just recertified my NRP and state license..... there is always hope!
/ loader joystick mod #10
Yea, my lever was easy.... I saw in your pic how it goes way down low and bends... does not give you too many options. You did a nice job on it.
NRP is national registry? EMS degree was just becoming a thing in the late 90's around here. By 2000, I was off the rig and doing something else.
Oh, you're the real deal, LS. Me, I worked on private services, the job was mostly gomer transports. We had occasional calls where we could play with the shocky paddles and tubing somebody, but each time I recall looking down at this poor old thing we were working on, and wondering...what's the point. Everybody was on privates with the goal of eventually getting on a fire dept, especially Chicago FD.
Real sorry to hear about your injury!
2001 Eagle 24ft Equipment Trailer (A61165)
2001 Eagle 24ft...
UNUSED WOLVERINE QMP3-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
PALLET OF WOOD FRAME WINDOWS (A62131)
PALLET OF WOOD...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
KUBOTA M135X TRACTOR (A62130)
KUBOTA M135X...
