Brush Grapple
/ Brush Grapple #1
abunchofidiots
Mt. Sidney, VA
Yanmar YT 235
After looking at the prices and heavy weight of brush grapples, I decided to make one that slides onto a quick attach plate just like pallet forks. The entire cost with disposables is still under $300. The weight is still light enough to not effect the lift capacity of a smaller tractor. It can also scale up to two grapples for one on each side of the frame.
/ Brush Grapple #2
That looks pretty slick. I have been thinking about building something similar. Let us know how it works!
/ Brush Grapple #3
Don't be shy about bracing. I'm concerned about the claw's ability to withstand the forces applied by the cylinder.
Looking forward to seeing the finished product!!!!
/ Brush Grapple #4
Yes it needs some pretty serious bracing. It would have been better to be wider so it could be braced better.
/ Brush Grapple
Wider would defeat the requirements of light weight, and quick attack pallet fork style. I'm also not sure how it being wider would allow for more bracing. There are fish plates at the joints where the 22.5 degree change takes place, not show in the pictures. That area may need made need reinforcement to distribute load away from the weld joint.
/ Brush Grapple #6
Being twice as wide as it currently is would have very little affect on weight. Being twice as wide would give it a lot more ability to withstand racking sideways.
/ Brush Grapple #7
Here’s your weakest link with very little ability to withstand bending sideways.IMG_8249.JPG
/ Brush Grapple #8
The bracing at that joint may require significant bracing.
Also not sure of the gauge of square tubing used? Pretty good chance you are going to bend the outer section?
As 4570 pointed out, the racking is going to start at the hinge. If the claw holds up to the stress, the channel iron may twist. Channel has little resistance to twist.
Start using it. Any weakness will show up quickly.
I had to backtrack and reinforce my claws twice. After a few years of use I also had to rebuild the hinge areas.
Someone much geometrically smarter than I can tell you how many lbs of force you are applying to each area.
/ Brush Grapple #9
The downside is it’s a lot harder to fix once it’s bent.
/ Brush Grapple #10
Absolutely!!!!
I understand wanting light weight. But that's secondary to dependability.
/ Brush Grapple #11
That was the same areas my cheap grapple failed. My Favor grapple is designed much better to prevent it.
/ Brush Grapple
Keep the info coming guys. This is my first grapple build. It is intended use is for moving piles of Autumn Olive brush.
/ Brush Grapple #14
Here’s the lid on my Favor grapple vs my titan grapple that was junk. The favor lid is boxed all the way up the center to prevent racking sideways, the cylinder is on a double mount vs one in the center, there’s a stabilizer tube all the way across the pins, and it’s ar400 that’s a lot stronger. The titan in the google image looks improved over the one I had. The cylinder mounts on mine were still the single post ones but they were cut out of the grapple body and 2 3/8 plates stacked. One 3/4 would be a lot stronger than 2 loose stacked 3/8 ones. It looks like they’ve added that tube across the back too. Mine just had the side plates spanning a good distance. Overall not much to keep the lid from racking sideways. It wouldn’t take a lot to withstand clamping a nice round log but clamping on only one tip of the lid or worse a slanted object that pushing it sideways is much harder to withstand. IMG_8255.JPGIMG_8256.JPG
/ Brush Grapple #15
And, even though the original intent is just some light brush, that changes quickly. :D
/ Brush Grapple #16
I'm a bit concerned about the tubing you're using. Seems a bit weak for that cylinder.
Usually the first project with hydraulics will requires some redesign or reinforcement after the first couple of tests. It happened to me on my backhoe and I'm pretty sure it happen to everyone. It's very easy to underestimate the power of hydraulics.
I'll leave a couple of pictures of a style of grapple we use here. It's designed to handle logs more than brush but it should work fine as well.
66504713_2329974887098146_973200831488720896_o.jpg60203338_2229690767126559_1900743961597706240_o.jpg
Anyway, keep up the good work. We're here to help with suggestions and tips. :thumbsup:
/ Brush Grapple #17
I practically have a degree in busting implements.
/ Brush Grapple #19
I have one I built a couple years ago I would post pics but can't figure out how to
/ Brush Grapple #20
I'm trying this. Just finished it. As OVRSZD said, I might use it for bigger things than it was built for. I'm hoping it works for me though.GP1.jpgGP2.jpgGP3.jpgGP4.jpgGRAPPLE D.jpeg
STORAGE FEES (A59914)
213098 (A64276)
213098 (A64276)
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
1999 AMERICAN EAGLE CLASS A MOTORHOME (A65643)
1999 AMERICAN...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
2021 Bobcat T770 (A64126)
2021 Bobcat T770...
