Steel siding/roofing from Lowes-pricing?
   / Steel siding/roofing from Lowes-pricing? #21
There lots ideas oh how to put it down some like wood slats think the air space is good idea, other over existing shingles, over shingles with a layer of tar paper, heavy over lapped. Next is where and how to screw down, Some say on the seam only to allow for expansion and others on the flats. So my barn is seams only no leaks, house on the flats no leaks. I like seams only and around the edges
   / Steel siding/roofing from Lowes-pricing? #22
There's a warranty when the instructions are followed on the material I used. The drawing shows one screw per flat plus one extra next to seam, then in the seams themselves.
   / Steel siding/roofing from Lowes-pricing? #23
   / Steel siding/roofing from Lowes-pricing? #24
If I pull up that same item number 24216, I get the same $61 price for a 12' piece which makes $5.08/Linear Foot. I know I get get the same item, same thickness, same color for $2.55 per foot.
   / Steel siding/roofing from Lowes-pricing? #25
29 gauge is very thin and cheap. 24 gauge is best, or even 26, but expect beer cans with 29.
   / Steel siding/roofing from Lowes-pricing? #26
Please don't forget the accessories for the steel sliding, such as self-screw, Butyl tape, and sealant.
   / Steel siding/roofing from Lowes-pricing? #27
I heard that some thinner metal might be as good as thicker because of a higher tensile strength. I rely on known builders that have a good reputation as to what is better.
   / Steel siding/roofing from Lowes-pricing? #28
I would guess that higher tensile strength isn't as important as to puncture resistance and stiffness. My gut tells me to go thicker. Interested in what professionals would say about this.
   / Steel siding/roofing from Lowes-pricing? #29
24 gauge is better than 29... think 2x6 vs a 4x6, which is stronger?
   / Steel siding/roofing from Lowes-pricing? #30
The thinner metal will puncture easier if branches fall on the roof. It also makes a difference if you have plywood decking under the metal vs open purlins. I'm building a 30x40 pole barn this Spring, and using 24 gauge metal with plywood underneath.
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
MISC CABINETS FLOORING (A54757)
MISC CABINETS...
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
30pc. 16ft.x 3ft. Grey Metal Roof Panels (A53424)
30pc. 16ft.x 3ft...
1R SILT FENCE PLOW (A52706)
1R SILT FENCE PLOW...
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
