Shouse Build
/ Shouse Build #1
desertdog71
Southeast, Kansas
Branson 2510H
This will be a long process, probably 2-2.5 years if you all want to follow along.
I'll preface with saying that I'm not someone that has worked in the trades, I'm not someone who grew up on a farm, operated equipment or anything like that. My wife does have experience in working in the trades but it's been a while. We're fairly confident we can do a good portion of the work ourselves and that's what we are going to do. We may end up divorced or one of us missing by the time it's all over. :laughing:
So the vision is a 40x100 post frame building. Half will be house, half will be shop/garage. We have designed the building and have it worked out exactly how we want it. Here's a 3D rendering of the building.
So we found some land we liked at a price we wanted to pay. We bought 10.3AC along an old coal mine strip pit in SE Kansas. The pit has long been filled with water, and stocked with tons of fish. Bass, crappie, bluegill, gar, carp, catfish etc. There's not many houses that have this kind of access. The vast majority of the land that was mined is now owned by the state and managed as a wildlife area. So anyways, we liked it and bought it.
When we purchased the place, we found that it had been mostly cleared in 1998 but had not been touched since then. Being winter it made things a little bit more accessible, or at least you could kind of see the ground. It's all very overgrown. We did manage to locate the spot we wanted to build though.
Once we closed on the place, I decided to rent a tractor and bush hog to clear what I could. I have no tractor experience at all but I managed to get quite a bit done in 7 hours. I cleared about a total of 4 acres. There was a lot of Sumac in the mix that was 1 to 1.5 inches thick, so it was slow going. Plus I didn't know the ground below me, and that slowed me down as well. The grass was all dry and seed and garbage was also clogging up the radiator about every 30 minutes, so I'd have to stop and clean that all out. No screen on the JD 3039R for whatever reason. I got a good amount clear though.
Having cleared a good area, we were able to get the survey crew out this past Friday to mark the property lines. We also drove in a handful of T-posts to mark the edges in case someone decided to pull the wood stakes for whatever reason. The t-posts will at least slow them down a bit. I have no reason to believe anyone is even poking around back in there but experience tells me to take measures just in case.
I also did some hillbilly perc testing yesterday to decide where to put the leech field for the septic. The area we wanted to use seems to be fine. I dug a few holes and filled with water, let them soak. Topped off and then measured the drop over an hour. I got between 3 and 7 inches per hour depending on the location of the holes. The county requires between 1 and 15 inches per hour, so I think we are good to go. We will have the septic put in by a pro though. It is the one thing the county actually inspects, and it does require them to certify you as the installer. So you can do it yourself but you have to take exams to prove your knowledge. I'll pass on that nonsense and let a pro do it.
I ordered a tractor last week to do some of the work. Mainly rotary cutting and some light earth moving. I will likely have to rent some equipment to prepare the build site and also get the driveway cut. I also have a friend that is an excavator and he offered to have me rent a dozer and he'd knock that out for me. I'm not sure where I stand on that yet. I at least want to attempt to do it myself, just for the satisfaction of doing it. If it ends up being a problem, I can always give him a call.
So that is where I stand for now. I return to work Feb 2nd until Feb 17th out of the country. When I return the tractor should be ready for pick up and I can get some more work done.
The plan is as follows for now.
1. Do more bush hogging and clearing. I have about 8-10 small trees and cedars to rip out.
2. Attempt to cut in a driveway.
3. Once driveway is in, lay down the base railroad ballast stone so heavier trucks can get in and out.
4. Get a 40 foot container delivered for storage of tools and materials.
5. Get the build site level and prepared for construction.
I will try to have this all done by September which is when we would like to begin getting the building up. We have a couple details to iron out with the building and we will order the materials once we are ready to begin. In the meantime we will get the site level, squared up, and holes drilled for the post frame brackets. Get those in and ready to go.
I should have a 7-8 week stretch from mid September until mid November to get the building up and dried in. That is the goal anyways. From that point we can take our time doing the rest of it. There is no rush except once we begin putting the actual structure up, I'd prefer it get done fairly quickly. I'd rather the materials not be laying around getting wet or walking off.
So yeah that's my project. It's either going to be very satisfying or it's going to be an unmitigated disaster. :laughing: I'm sure we will have our share of costly mistakes and moments of what the eff were we thinking, but whatever. I think we are capable of doing the job, and it's a journey worth taking.
/ Shouse Build #2
Was Shouse a misprint in your title?
Congrats on the land, I'm looking forward to following your progress.
On your 3D image of the building, why the different roof lines? Making it all the same height eliminates potential issues in the future for leaking.
/ Shouse Build
I'm thinking "Shop/House", making it a Shouse. :thumbsup:
Correct.
As for the pitch change on the porches, that is one of the adjustments we are making prior to ordering the building. It will be 4/12 all the way down.
/ Shouse Build #5
DD: it looks like you and your bride are in for a fun (and maybe stressful) ride so hang on and enjoy it. while i've never built a home to live in I've done many projects with my bride of 32+ years at my side. communication is the key so keep talking and working out stuff together.
can I ask how old you are and do you have kids?
sounds like a great spot you've found and since you are in Kansas do you have to build your home TORNADO PROOF?
i'm a new member here too and still want to welcome you cause there are a ton of great guys here. also Eddie seems to know more than most about building from what i've read so far.
also since you are on a Tractor forum some of the guys probably want to know what you are buying and having delivered.
GOOD LUCK and this should be fun (at least for us)!!
/ Shouse Build
No such thing as tornado proof. The house I live in currently was built in 1880 and it's still here. We will be placing a metal shelter inside the garage portion in case we need it but that's about it. The building itself is engineered to handle the weather here.
I'm 48 my wife is 43, our kids are 18 and 16. They'll hopefully be moving on with their own lives. :laughing:
I ordered a Branson 2510H, just needed something small to do bush hogging and mowing and drag the driveway every now and then. I could have went bigger but didn't see the need once the property was established and it's really not the right tool for earth moving anyways. I know it's a weird brand but the people that own them seem to like them a lot, and I liked the dealer a lot more than others I visited. If it's crap I will live and learn I guess.
Yeah fun, I'll make sure to take plenty of pics and video of me doing stupid things and nearly killing myself. I'm sure those will get a laugh. Nothing like city folks moving to the sticks and doing stuff they probably shouldn't be doing themselves. That's hours of entertainment. :D
/ Shouse Build #7
Since you are not building for awhile yet, and this is your first time doing this, one of the things that I've run into with every single floorplan that I've looked at, is they need fixing. I read in one of the Trade Magazines that I get how it takes about 7 tries to build the house the way you really want it. Most people put things into a new design that they saw somewhere else and liked, but fail in incorporating them into the rest of the design. Other mistakes are in the flow of the house, storage, bathroom layout and most of all, how to save significant money by not doing something that is never needed or used. Whirlpool/Jacuuzi type bathtubs are probably number one on the list of wastes of money for most people. On average, they are used 3 times. In most of the bathroom remodels that I do, the bathtub is almost always the thing that gets removed so they can have a much bigger shower, or another counter, or just more storage. I've only had a few clients that wanted a bigger bathtub, or actually used it on a regular basis. Walk in showers without any glass is where I make most of my money. ADA without a lip is probably the nicest way to take a shower in my opinion. While it can be hard to hear others critique a design that you have worked very hard on, there is gold in some of those opinions that will make your life so much better in the long run.
/ Shouse Build
The spare bath will have a standard tub/shower the master is a walk in shower with 3 foot entry, small lip as you described. We will do that ourselves, we built one in our current house and love it. We have the house built out of Legos. :laughing: That's about the closest thing to a floorplan I could share. The actual floorplan we did is on graph paper and the scale of it is just too big to scan or do anything with.
There's not much waste in what we are doing in my opinion. The walk in closet could be smaller. I don't really need an office space in the garage. Those are just walls though, and not much to them. We're not going crazy with finishes and cabinets, counters, etc. Just want a good solid place to live and eventually die in, away from neighbors. I'm still on the fence about radiant heat. The weather here can be 10 one day and 60 the next, so I'm not sure its a good fit here.
/ Shouse Build #9
DD: one thing that is COMMON with all good builds whether it's a garage, house or even a small shed is the PREP. don't skimp on gravel and grading even if you might need help or if I might cost a bit more. also pouring your driveways and slabs a bit thicker and having a pro looking over your shoulder to make sure rebar and piping is in right locations is a good idea too.
I like the LEGO idea for modeling your new home. did you mention how many square feet your home and garage are going to be? at one point my bride was drawing up house plans for us to move and as our 5 kids moved out our 2000 square foot home seemed better even though I don't have a shop so if you'd like ideas on how to design the inside of your home just ask and i'll see if i can get her to see it or find some of the old plans.
since you mentioned fish are in the lake/pond are you able to swim in it or just row a boat out there?
good luck!!
/ Shouse Build #10
Congratulations, you are doing the same thing my wife and I did in 1971.
Forty nine years later we are living in the same house with no intent to sell. When we started I was 28 and my wife was 25, we had a 1 year old son.
For what it’s worth, here are a few lessons we learned through the school of hard knocks.
First off, you admit to having no real life experience in the construction trades. Not necessarily a bad thing but expect a steep learning curve ahead. My first suggestion is, a 40 X 100’ building is no small undertaking and as such, I would contract out the erection of the shell, cladding, and roofing. Six by six timbers and forty foot trusses are not something most spouses should help with. Secondly, I assume this to be a slab on grade construction so somewhere around 50 cubic yards of concrete, again necessitating a good sized crew to place and finish. Electrical, mechanical, and plumbing infrastructure are pretty permeant especially rough pluming buried beneath several inches of concrete floor. To paraphrase the building process there is a huge amount of just plane grunt labor that can only be correctly accomplished by experienced crews with the necessary specialized equipment and experience.
I applaud your enthusiasm, it can be done but the use of professional help allows time to work on the stuff makes a building an extension of your dream and long term goals.
Keep the TBN gang posted on your progress and never be afraid to ask questions the resources here are world wide....
B. John
/ Shouse Build #11
I agree with Budweiser John. Some specialties are better contracted out. Getting the building erected and closed in is relatively fast, and not the most time consuming and expensive part of construction.
/ Shouse Build
the pit is plenty big enough for a boat in fact some folks have docks and boats they use on them. This pit winds around a good mile or so and averages probably 150 feet across and 25-30 feet deep.
Concrete will be contracted out. The actual raising of the building will be us doing the work. My wife is plenty capable, she's not fragile or helpless. I understand the concern but it just doesn't apply to her. She's far more knowledgeable in the trades than I am, she's done this kind of work before, so I'm not worried about it. I'll probably slow her down honestly.
My only real concern with all this is that we're not youngsters anymore and it does take a lot out of us sometimes and the time to recover tends to be longer. We're not going to know until we jump in and start doing it though.
Yes, I'd prefer to have a crew put the shell up, but these crews basically want to double the cost of the building to put them up. I've been quoted $140K to put the building up vs $50K for materials and I figure another $30K concrete. I don't see $60K in labor there, so I won't even consider paying that much.
/ Shouse Build #13
Sounds like your place is near Big Brutus. That thing is huge.
/ Shouse Build
Here, you can laugh at my LEGO house. The garage is half so 2000 sq feet, then another 2000 sq feet is the house. 3 bed, 2 bath, great room. 10 foot ceilings over the house. 12 foot over the garage. Garage has an office built in to the corner for me to escape from time to time. 2 cars, a boat, tractor, and tools to be stored in the garage. It's all connected. Slab on grade, zero entry, ADA compliant with 3 foot doorways everywhere. Floor will be stained concrete throughout.
Here is the Master, Master bath and Utility.
Living and Dining (great room)
Second and third bedrooms.
Where it's going. (I'm parked in the kitchen)
Picture from down at the water.
/ Shouse Build #17
Chim: I agree an porta potty or maybe even a custom built outhouse might be the first building to build. and so you don't need to tear it down how about down by the lake so you can use it later?
DD: in case you'd like to post your pictures either medium size or full size instead of thumbs I just learned how over on the Natures Photo thread that you might post up a few of your cool pics on while you read how the other members helped me. here's the link: https://www.tractorbynet.com/forums/photos/418669-cool-nature-photos.html
if you like the thumbnails that's ok too cause we can click and have them full size, but thought i'd mention this to you cause I know I'll be watching your progress along with others and bigger pictures get more eyeballs.
cheers and again good luck
here's a medium size picture
/ Shouse Build #18
Like the lego house.... but just one thing. The only person standing appears to be holding a sledge hammer. :eek:
:laughing:
Anyhow, looks good. Nice property, too. Good luck on your build.
/ Shouse Build
:laughing:
Sledgehammer and a pirate hat. My wife built the lego house, maybe I should be concerned. :laughing:
/ Shouse Build #20
It sounds like you wife has a sense of humor. That in itself will come in handy. 25 years ago we built our own house and ran out of humor toward the end. We got it back though!
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
