541 loader seal kit
/ 541 loader seal kit #1
dieselbeef
Gold Member
myakka city
bx2200..jd 2010 loader backhoe tractor
needing to rebuild the bucket tilt..
any deals....or just shoot it to the dealer?
/ 541 loader seal kit #2
Any local hydraulic shop could help you, they rebuild cylinders all the time.
/ 541 loader seal kit #3
Here's JD price
parts key #26B AH212088 Hydraulic Cylinder Kit ADD 23.57 USD
parts key #25 AH148823 Seal Kit ADD 34.64 USD
thank u sir...im just gonna get the rod seal..looks like a Teflon ring on the piston..itll go back in ok so im just gonna fix the 20$ / gallon leak...at least its a repairable cyl
/ 541 loader seal kit #5
My 541 bucker cylinder died on me. I found an exact replacement cylinder(John Deere wanted $890) from Magister Hydraulics for $147 with free shipping!!! Ask for Jilvanny the sales manager and he will give you a better deal. My cylinder is perfect. Hope others will check them out. Mike Mount
so now I need to do the lift cyls..both of them...before hay season
/ 541 loader seal kit #7
Sounds like your luck is going like mine. Lol
I have found it cheaper to buy new cylinders from Magister Hydraulics than to pay the fee from John Deere for the rebuild kits. It took less than thirty minutes to change out the two bucket cylinders with new ones and they worked perfect. Deere wanted within ten dollars for a rebuild kit as I paid for a better built cylinder. Best of luck to you. We are in the middle of hay season right now trying to beat the rains.
/ 541 loader seal kit #8
Here's JD price
Just for Pete's sake, I looked up current prices.
parts key #26B AH212088 Hydraulic Cylinder Kit NOW $39.59 USD
parts key #25 AH148823 Seal Kit NOW 41.02 USD
$80.60 PER side for just the seal kits.
One of the lift cylinder kits is OUCH!
AHC13485 Hydraulic Cylinder Kit - $70.39
/ 541 loader seal kit #9
Hello Mike Mount,
Do you happen to remember part number for the bucket cylinder that you got from Magister Hydraulics as replacement for the one John Deere sells for $890? I broke the thread end of the rod on one of my cylinders (AH228450 Hydraulic Cylinder) and will need to replace the cylinder and would like to use the Magister Hydraulics Cylinder. For the price I will replace both cylinders on my JD 5320 with the 541 loader. Thanks for any information you can give me. Larry Hatfield
/ 541 loader seal kit #11
Thanks for your help. You tube video gave me what I needed. Larry
/ 541 loader seal kit #12
Hello Mike Mount,
Could you please let me know what part numbers they have that fit the 541? The lift and bucket curls too if they have them.
Also, if you have to modify anything to get them to fit.
/ 541 loader seal kit #13
I will get back to you.
/ 541 loader seal kit #14
Hello Kyle,
I checked key elements of the John Deere AH228450 cylinder used on the bucket rotation (bore size, rod size, mounting hole size, total o誕ll length and most important is the cylinder stroke). The closest Magister Hydraulic Cylinder I could find that could be used as a replacement on the 541 loader is WTG 2.5 X 24. Only reason for picking this cylinder over others that would work is the hydraulic ports to hook up hydraulic lines are on top or bottom instead as on the sides. Also, the WTG 2.5 X 24 cylinder would need spacers on the 1 mounting pins to center the cylinder. Below is web site for Magister Hydraulic that shows standard cylinders. Larry
https://www.magisterhyd.com/wp-content/uploads/2019/12/Catalog_2020_Web-1.pdf
/ 541 loader seal kit #15
Thank you. Have you considered the Deere rebuild kits? I need to rebuild ours, but 1st I need to make the spacer that fills in the tube's internal groove...You put the spacer in to keep the keeper from falling into the groove while removing the packing or whatevertheycallit.
/ 541 loader seal kit #16
Use bondo if you don’t have the filler piece.
/ 541 loader seal kit #17
As a matter of fact I ordered the rebuild kit from my John Deere dealer yesterday. I did the repair on the cylinder rod to where it is usable. I have a lathe and was able to make the internal groove packing ring out of PVC pipe so I could remove components in the end of the cylinder. The 2 seals in the 菟acking as you call it were little hard to get out but can be done with small screwdrivers, I used 2. I値l let you know how reassemble goes and I test everything out.. Larry
/ 541 loader seal kit #18
As a matter of fact I ordered the rebuild kit from my John Deere dealer yesterday. I did the repair on the cylinder rod to where it is usable. I have a lathe and was able to make the internal groove packing ring out of PVC pipe so I could remove components in the end of the cylinder. The 2 seals in the �acking as you call it were little hard to get out but can be done with small screwdrivers, I used 2. I値l let you know how reassemble goes and I test everything out.. Larry
If you are for sure going the repair route I would go and buy the repair kits from John Deere as it has the internal groove tool to remove everything from the cylinder.. Larry
/ 541 loader seal kit #19
Yes, like you I have a lathe available. I've made the same filler rings for my Deere 430 loader with smaller diameters. If you can make your own filler rings, You can get by ordering just a couple of seals/orings and packer rings for a bit cheaper.
Heavy-Duty Round Livestock Bale Feeder w/ Hay Saver (A66408)
Heavy-Duty Round...
2021 CATERPILLAR 320 EXCAVATOR (A65053)
2021 CATERPILLAR...
2001 Freightliner FL112 T/A Wet Kit Day Cab Truck Tractor (A64556)
2001 Freightliner...
Crane Carriage System for Steel Baskets (A65579)
Crane Carriage...
2018 Kubota SVL 75-2 Skidsteer (A65579)
2018 Kubota SVL...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
