Where to mount a tool box?
/ Where to mount a tool box? #41
/ Where to mount a tool box? #42
/ Where to mount a tool box? #44
What is the name of that tool box kit that you posted? Or what website did you find this one?
Thanks
For the boxes, these are on the ASC site.
Tractor Tool Box Red | Agri Supply 3942A
Tractor Tool Box Green | Agri Supply 3943A
For the steel basket / tray ...
TRACTOR TOOL TRAY by Great Day ~ MADE IN THE USA! - YouTube
Universal ROPS Mount Tractor Tool Tray
ROPS Mounted Tool Tray
https://www.amazon.com/Great-Day-TT400-Tractor-Tool-Tray/dp/B01BD52K3K
https://www.amazon.com/Kubota-Chalm...GN081WZ99HZJWEWNK&qid=1576511792&s=automotive
Here is the manufacture website ...
http://greatdayinc.com/products/lawn-garden-accessories/tractor-tool-tray/
Now, this setup is far better than using magnets. Magnets over time will cause RUST to happen between the magnetic surface and the mating metal.
/ Where to mount a tool box? #45
Thanks
If you got sticker shocked by my first rely, then think outside of the box and look elsewhere for the application.
ATVs have used many mounted mesh trays/baskets/bins.
Black Widow Steel Mesh ATV Front Rack Basket | Discount Ramps
Kolpin Steel Mesh ATV Rack Basket | Discount Ramps
Amazon.com: Guide Gear ATV Front Basket: Automotive
This is a neat one. Should the tractor seat be an issue getting in the way, use this type.
ATV Rack, ATV Rear Rack, ATV Front Basket | Colorado Rugged Racks
Like most things, these are typically China made. A-B-C-D tend to fit the tractors.
ATV Basket from China Manufacturer, Manufactory, Factory and Supplier on ECVV.com
Here's one that you can mount in the bar strip to close the slot and then to the ROPS.
https://www.amazon.com/Universal-Basket-Cargo-Carrier-Mounting/dp/B0053SSD9O
/ Where to mount a tool box? #46
I have that basket also. Had on the backside of the ROPS. It was in the way when I went to use the 3 point. So I moved it to the side using different braces and resting it on the fender. Its great. Love it. Use it all the time. Just don't care for it where it was designed to go.
/ Where to mount a tool box? #47
That is very nice. Thanks for sharing this option. :thumbsup:
There are also some front mounted ATV basket types that would mount to a tractor front weight bar. For John Deere's and Yanmars, it would be a quick attach when needed option.
/ Where to mount a tool box? #48
Mount on the front ...
/ Where to mount a tool box? #49
California the golf bag is a great idea!! I think I know what I'm gonna do.
When stopping in at the Goodwill or Salvation Army stores, these bags are there for under $10. Sure, they are a bit worn, but not too bad for a portable ROPS sack. :cool2:
/ Where to mount a tool box? #50
Here's the post that Jtullis referenced. I use lots of Goodwill stuff repurposed to carry tools on the tractors. $10??? ... $5 is my upper limit for junk like this. :D
https://www.tractorbynet.com/forums/yanmar/356585-where-mount-tool-box.html#post4443217
And this pic shows the plastic toolbox lashed to the qhitch. Not to steer this thread off-topic or anything :) but this pic also shows the lifter I made for the spike harrow, built from a re-purposed exercise machine that a neighbor abandoned when she moved.
Ok, back to the topic of toolboxes.
/ Where to mount a tool box? #51
:thumbsup:
Hey, did you put any drain holes in the bottom of the bags with a plastic grommet should it rain?
/ Where to mount a tool box? #52
:thumbsup:
No. The tractors are never out in rain, almost never outdoors overnight.
(Unfortunately the appearance of both shows they spent years, decades, left outdoors before I bought them).
/ Where to mount a tool box? #53
Figured I would jump in as well.....after researching a number of options, this worked well for me:
/ Where to mount a tool box? #54
LIKE
:thumbsup:
Nice pix resolution. The box is a Husky. Looks durable and it should keep rain out. I do like the clasps on the box as vibration could be an issue. Plus, a good closed box will keep our tiny critters making a nest inside.
For the fire-extinguisher, is that held on with velco straps ????
/ Where to mount a tool box? #55
LIKE
:thumbsup:
Thanks. It stays bone dry and the clasp has never loosened up. The extinguisher mount does have Velcro straps and has worked well for a number of years now. It is actually sold as a holder for a JEEP, but also fits the ROPS nicely.
I also have a "Woodsman's Pal" mounted on the ROPS. Very handy for when the need arises to take care of a small limb,brush, sapling, etc.... (pic from when they were mounted on my old tractor)
/ Where to mount a tool box? #56
Had no idea what a "woodsman's pal" so I looked one up on Amazon!! WOW that's a lot of money for something that just sits on the rops.
/ Where to mount a tool box? #57
I welded a pc of 2x2 angle between the uprights of the ROPS and mounted a tool box on the angle.
enhance
THe problem here would be not being able to see your 3 pt hitch now . I had the same issue and had to move the tool box .
/ Where to mount a tool box? #58
I got one for $4 at H-F. :thumbsup:
18 in. Machete with Serrated Blade
It's come in handy a bunch of times already. Whack things or use the serrated blade like a saw, it does well.
/ Where to mount a tool box? #59
If you look up what a "woodsman pal " is it's a brand with that fancy wood handle and some short looking shaped machete. But same basic tool. The $5 works as well. I have some combi tool thing that's like machete and hatchet I got free I could do the same with
/ Where to mount a tool box? #60
Most of my tractors came with tool boxes, but usually I want a bigger tool box, so I mount a second one.
Once I figure out where it will fit, I bend up some flat bar out of my scrap steel box, and use existing threaded holes in the tractor to bolt it to,
Then it's just a matter of bolting the tool box to the flat bar,
The extra boxes have worked out pretty good for me...
SR
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
Pemberton Inc 416469 72in. Loader Forks and Frame (A64194)
Pemberton Inc...
3pt Counter Weight (A64127)
3pt Counter Weight...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2004 International 7400 C&C 017797 (A62613)
2004 International...
2023 Kubota L6060HST Compact Utility Tractor (A63688)
2023 Kubota...
