Tractor Sizing Compact TLB for cutting trails into a sloped hillside?
   / Compact TLB for cutting trails into a sloped hillside? #21
How wide do you want to make these trails/roads? Are they for ATVs or trucks or something else?
Keep in mind with a tractor and BH (or a TLB) the outside stabilizer needs to be on ground that's solid enough to take some weigh. If you're making the road by pulling from the uphill and piling it on the downhill, the downhill/outside will be loose and unstable until it's been packed down. So you'll need to make the road wider than the outside width of the stabilizer pads. A tracked excavator won't have that problem, and it's probably narrower as well.
Another consideration is erosion. You want to make the roads so they won't cause erosion problems, both so they don't wash out and also so you're not damaging your land, clogging streams, etc. Someone with a lot of experience building roads in your area (and thus familiar with your soils) should be able to design roads that minimize erosion.
   / Compact TLB for cutting trails into a sloped hillside? #22
Rent a dozer with the operator. Be clear on what you want, get a couple estimates. Experienced operator will do the job quickly and correctly. Maintain with your tractor later.
   / Compact TLB for cutting trails into a sloped hillside? #23
This is in northern California, in the foothills.
So, in the Sierras then?
I have over a mile of trails now on my 19 acres, some built with my TLB, some by hand, and some with my newly-acquired mini-X. My wider trails are done with the Kioti, and they are about 6-feet wide at their narrowest, and 25% slope at their steepest. My "foot" trails are narrower, and only 4-ft wide at their narrowest, and as much as 33% slope. I started the foot trails over a dozen years ago, with pick and shovel. Progress was slow, of course, and got even slower as I got older and more decrepit.
So, I got the mini in 2018, and now have a year of productivity. Wow. I shoulda gotten it years ago. Now my foot trails can safely be traversed with my 4x4 ATV, which is 42" wide. When cutting a new trail, I can only go up the steeper slopes even with my tracked machine if the soil conditions are just right. Switch-backs take a lot of extra work to get right.
Even my wider tractor trails at their steepest can not be navigated with my tractor if the surface dries out too much. I have crappy R4 tires, and they are a huge compromise to traction.
If you don't want road-width trails, then a dozer or larger excavator is not gonna work. You CAN build certain types of trails with a TLB, but you must get AG tires, IMO. Most of those newer sub-compacts are sold with R4s, which is not good.
Some folks disdain my tiny Chinese mini-X, but it was less than $8500 new, and is only 3-ft wide. When I cut a new trail, I shoot for 36" of undisturbed cut ground, with the fill on the side adding to a total width of about 4-5 feet. I do not drive on the fill part (with ATV or mini) until it has consolidated for one season. Ideally, I would use a plate-compactor for the fill, but they are too heavy to haul up the mountainside.
   / Compact TLB for cutting trails into a sloped hillside? #24
dfkrug: "Importing and modifying a new mini excavator from China"
LINK: https://www.tractorbynet.com/forums...-modifying-new-mini-excavator.html?highlight=
Interesting.
   / Compact TLB for cutting trails into a sloped hillside? #25
Always a tough call. Of course the best would be two machines, a Mini Ex and and a CUT would be my desire. Maybe buy a used Mini Ex and sell it after you have put the majority of road work behind you. Then you can maintain, add some improvements, and do other projects with your CUT. You will want some teeth on your FEL bucket for any kind of digging. I highly recommend a Piranha Tooth Bar!
I have cut hundreds of feet of trail road into a steep/challenging side hill similar to yours with my BX25D using both the back hoe and the the FEL bucket with PTB. But it is very slow going and can be a puckering experience at times. I also highly recommend wheel spacers to widen stance to increase stability.
   / Compact TLB for cutting trails into a sloped hillside? #26
While I generally favor a larger tractor, I think your selections could work if you go slow and safe.
That's a good video, cuz it shows you can really do a lot of work, even with a very small machine.
You can see how light it is when the operator is dumping a bkt of dirt on the top of that mini-mountain. When the bkt reaches the end of its travel, the whole tractor kinda jerks in response. Powerful hydraulics on a very light machine is a really different experience vs. running 2-3 ton tractors. My 2000# mini jerks me around just like that.
   / Compact TLB for cutting trails into a sloped hillside? #27
The bummer about an excavator or dozer is that it would be a single purpose machine for me, and wouldn't help with things like maintaining my driveway, moving gravel around, making burn piles, etc... In that regard, a CTL would be much more appealing. But I'm just not sure if a CTL could really dig into the hillside, having never used one here.
A machine designed to do everything does nothing particularly well. Do you drive screws with a hammer?
Any track machine has a major week point...its track. Quick to wear, expensive to fix. When working on slopes you have no where to turn around. So that means LOTS of driving around, 50% of the time with nothing in the bucket. Yes you can turn in one spot, but that grinds up the track super quick. Any TLB means you will be digging with the backhoe, drive out, drive back, scoop/level and repeat. A SCUT TLB means you will be doing that every 4-6 feet.
If you want to save money hire an experienced operator with machine. Then buy a SCUT to cut your grass, clean up the garden, ...if you need a very expensive powered hand shovel buy a backhoe attachment for the SCUT.
   / Compact TLB for cutting trails into a sloped hillside? #28
This is what I would do also. The operator should also know how to cut it so it will not wash out.
I had a Kubota 5030 with a BH90 backhoe and did cut flat trails on the side of my dam, it did take a long time. the getting on and off is tiresome. I was digging in sand and clay, no trees or rocks.
   / Compact TLB for cutting trails into a sloped hillside? #29
Hire an experienced dozer operator with a D6 sized dozer with 6 way blade. The blade width will be plenty wide for a road for your tractor.
He can likely build your trail/road in a day or 2 at the most. This size dozer around here rents for $85 per hour including operator. They can do an amazing amount of work in an hour when just cutting into a hillside and dropping the dirt to the low side. Then a CUT with box blade can keep it smoothed out later.
I could likely dig that out with my B26 TLB but it would take a long time and digging out rocks is hard on the backhoe. Even with owning my own TLB, I would hire a dozer to do similar work.
   / Compact TLB for cutting trails into a sloped hillside? #30
I seem to remember at one time that CA was helping people with fire breaks and fire access roads. Not sure if they still do, but might be worth checking into.
(16) 12" CHANNEL IRON (A57192)
(16) 12" CHANNEL...
2017 FORD F-450 XL BUCKET TRUCK (A57192)
2017 FORD F-450 XL...
UNUSED FUTURE XJ5T-5T HYD THUMB CLAMP (A57193)
UNUSED FUTURE...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
2010 Chevrolet Tahoe SUV (A53424)
2010 Chevrolet...
2006 Mercedes-Benz (A55758)
2006 Mercedes-Benz...
