   / Share Pics of People Hauling or Towing Something Wrong #11,831
A little heat for that boom would straighten it right out;)
   / Share Pics of People Hauling or Towing Something Wrong #11,833
That should buff right out. :shocked:
   / Share Pics of People Hauling or Towing Something Wrong #11,834
For hauling motorcycles and ATVs both in my truck bed and on my trailer, I have a bunch of these straps, and really like them:
https://www.amazon.com/gp/product/B017BYSJ7I
1.5" wide, 1000 lbs WLL, 3000 lbs breaking strength, and carabiner hooks on both ends so they stay put.
   / Share Pics of People Hauling or Towing Something Wrong #11,836
A good chain and a stout tree.
That boom cylinder is designed too long to start with,,
just cut off the bent portion, and weld a new end on the remaining straight part of the shaft,,,
If you extend the cylinder while welding, the heat will not damage the seals,,
I cut the rod with a Port-A-Band,, works well,, no need to even remove the cylinder from the machine!! :thumbsup:
:D
:laughing:
   / Share Pics of People Hauling or Towing Something Wrong #11,837
DiggingIt, the bent cowling means the slew motor and engine are destroyed, and there is almost certainly major damage to the slew ring gear too. Plus boom damage. SCRAP.
   / Share Pics of People Hauling or Towing Something Wrong #11,838
If it flexed enough to break the track I’d hate to see the rest of it. Best case the chains were hooked to the track and ripped it off but in any case that machine is in bad shape. There’s probably a few good parts but that’s pretty much scrap.
   / Share Pics of People Hauling or Towing Something Wrong #11,839
Are you serious ? Nevermind .
   / Share Pics of People Hauling or Towing Something Wrong #11,840
8 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
8 Piece Mini...
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
EZ GO Terrain 1000 Utility Cart (A56857)
EZ GO Terrain 1000...
Sheets of Tin (A57149)
2013 Vermeer SC1102 Towable Brush Chipper (A56857)
2013 Vermeer...
1634 (A58375)
1634 (A58375)
