hi lift jack tips and tricks?
/ hi lift jack tips and tricks? #61
One thing that has stuck in my mind regarding jack-alls is seeing a man changing a tire on his half ton with one. He had a flat rear tire and had pulled off the highway onto an approach and had the jack under the rear bumper towards one end of it and he had it jacked up very high. He had the tire off and was about to put the spare on when the back of the truck started to go sideways because he had so little weight on the other tire, it just slide along the ground. Of course that meant the jack started to lean sideways also and he jumped up and tried to stop it but before he got hold of it, the angle became too great and the jack slide off the end of the bumper at extremely high speed and the top of it hit the man in the thigh. I was surprised it didn't break his thighbone but it definitely hurt him something terrible. I was a passenger in a tandem digger truck pulling a trailer full of power poles and it happened right there before our eyes; we were just feet from him when it happened. We would have stopped but we saw in the mirrors that a car had pulled over to help him so we kept on driving down the highway. Bottom line is they can be very dangerous jacks to use when lifting a load that can move around on you.
/ hi lift jack tips and tricks? #62
Interesting happening there Mace. I usually had my Hi Lift strapped behind the winch on my Jeep. This was the time we lived in Alaska. Many, many times when stuck and no anchor point around we would use the Hi Lift. Jack up the rear of the Jeep - a couple of guys would push it sideways and out of the ruts. Same with the front. It would lean over and fall off the jack but it would also be out of the ruts.
You are SO correct though. If you got in the way of the jack or handle as the Jeep was being pushed sideways and off the jack - very likely some body part was going to get broken.
We never had anybody get hurt - the Hi Lift would smack down so very hard on the ground. More than obvious what was in store for anybody who would get in the way.
/ hi lift jack tips and tricks? #63
You would think lawyers would stand in line waiting to sue manufactures of those things. I've seen new ones that were as cantankerous as an old one.
/ hi lift jack tips and tricks? #64
A lot of the guys that I work with won't use them because they're so unstable. I find that I don't need the jack or my come-along as much as I used to, ever since I started driving trucks with that marvelous new option... Reverse! :D
One of those things I learned the hard way, walking can save a lot of time when the other choice is to drag the truck through the mud.
/ hi lift jack tips and tricks? #65
We use them all the time out on the trails for our Jeeps, yes they can be dangerous but then again, a little common sense goes a long way!
Keep them well lubed and they work much better and don't, NEVER, let go of the handle when letting it down, good way to get a broken jaw!
/ hi lift jack tips and tricks? #66
A little unusual use of a red bumper jack but I have been overhauling the floating portion of my dock. One of the floats (stack of tires filled with closed cell foam) had broken loose. On low tide today I used my red jack to lift one end of the dock so I could get the float back into position. You cannot see it but I have a 2x6 under the jack that compressed into the sand. I had to put my full weight onto the handle to get a ratchet up, but it did it. I have another red jack at a remote property that I was kicking myself to not have grabbed to double up the jacks. I have no idea what weight I had lifted but my I weigh in at around 200 lbs so whatever that computes to I was lifting.
Oh, and yes, I rinsed the saltwater off of the base so it does not start to rust. :thumbsup:
/ hi lift jack tips and tricks? #67
Call them there jacks widow makers, that jack handle slips out of your hand at the wrong time it will do some brain damage but other then that we have used them to jack up small buildings and a lot of other stuff besides changing tires or getting unstuck, have one in both pickups.
Jim.
/ hi lift jack tips and tricks? #69
Yepper!
/ hi lift jack tips and tricks? #70
Rainy day so here's some pix of a HiLift ('farm jack') project.
Some darn fool :))) ran the corner of the loader into the spike harrow where it was hiding in tall weeds.
These photos show straightening it.
Yes these are dangerous. I'm cautious, I've had it fall when lowering something but I was a safe distance away. As I finished this project it got me, I reached underneath to switch the lever from Lift to Drop and that lever moved with such force it bruised my finger between the lever and the jack frame. I should have poked that lever with a long screwdriver.
20191002_134312rFarmJack1-SpikeHarrow.jpg20191002_141317rFarmJack2.jpg20191002_162409rFarmJack3.jpg20191002_171847rFarmJack4.jpg20191002_173659rFarmJack5.jpg
And a bonus pic, another project underway. Some snowplow edges were in in a friends surplus-auction win. He gave them to me, I bolted up the iron parts to make a simple land plane. It works great. I'll improve the design a little then weld it solid. I pull it from the drawbar under the differential, plus have loose chains that go over the ends of the loader forks to lift it for turns. Anybody need the rubber edges that were bolted to these pieces? (They're visible under the workbench).
/ hi lift jack tips and tricks? #71
Keep the release mechanisms lubed. Everything else is Darwin type stuff.
/ hi lift jack tips and tricks? #73
And discard it when the pins get worn and won't slide easily over into the mast. In some modes there is only weak spring pressure to slide them over. I had two yard-sale Hi-Lifts and got rid of the worn-out one after too many scares.
/ hi lift jack tips and tricks? #77
Your land plane is very similar to what what we used for 10 years to maintain out stretch of gravel road.
We pulled it with an old willis jeep and used small tires between lengths of chain to act as shock absorbers.
Those rigs do a great job cutting down the bumps and filling in the dips.
The secret is the angle blades as it moves the material sideways to fill the voids.
A hint 4 U,
Shorten the trailing ends of the 2 angled blades so as to keep the material within the range of the next blade.
/ hi lift jack tips and tricks? #78
Yes! I wanted the blades laid out as you described, but for this trial prototype I bolted through existing holes. It levels beautifully but it also deposits a little ridge of material out beyond the leveled area. Now I'll set it up so the material spilled off the trailing end of the first angled blade is captured by the leading edge of the second blade. Then weld it up.
Tires in the pull chain to absorb shock? Why? I assume this would climb over any irregularity anticipated in a roadway.
/ hi lift jack tips and tricks? #79
I have a Hi-Lift jack. It's very handy. Almost indispensable when it is needed. I bought the Hi-Lift foot base and that helps with stability. Used it most recently to raise the trailer to change a flat. Pulled fence posts with it. Even pulled some small trees out of the ground. Raised corners of buildings. Stretched wire once but it wasn't that great because of the weight. I have several sizes of bottle jacks and a couple screw jacks. The Hi-Lift jack does some things better than any others. I compared the off brand look-a-like to the Hi-Lift and paid a little more for the Hi-Lift. Don't regret it.
Good thread. Good advice.
11in. Bucket with Teeth Excavator Attachment (A64194)
11in. Bucket with...
UNVERFERTH GW530 GRAVITY WAGON (A64278)
UNVERFERTH GW530...
250 gal Livestock Lick Tank (A66408)
250 gal Livestock...
2020 Hino 195 Landscape Dump Truck (A64556)
2020 Hino 195...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
