Material for Porch Ceiling
/ Material for Porch Ceiling #1
buck12
Mississippi
Kubota 5460HSTC
I am in the process of building a small cabin on our rural property. This is not a house we will ever live in permanently. The property has been in the family for well over a 100 years. My goal is to build something that can be handed down to my kids and grandchildren. With that said I don稚 want fancy, love low cost, and want this cabin to stand up to the test of time.
I am at the point of choosing material for the porch ceiling. I am thinking exterior plywood. The porch is 8 x 32? The rafters are on 16 centers. Is there a material better than plywood? If I go with plywood how thick?
/ Material for Porch Ceiling #2
You might want to see if T1-11 panel would work -- it would look better than plain plywood and cost is similar. Make sure it's a reputable brand, as the cheap stuff likes to delaminate (same is true of plywood of course). I have found that the good T1-11, when painted or stained, will last a long time.
The other option, if you have access to it, would be rough sawn pine boards. That is an economical material and looks great on a ceiling.
If you have wood bees in that area, choose your materials carefully for fascia and trim. They don't normally eat into a ceiling surface, but they'll love every other wood surface around a ceiling.
Thanks. Most of the cabin is Hardi Plank so insect damage should be minimal. Is T1-11 available with a bead board look? How thick should I go?
/ Material for Porch Ceiling #4
You could check out metal panels, some of which have the look of narrow planking.
I did my porch roof with is and it makes a bright room as well as is permanant.
/ Material for Porch Ceiling #5
You know, Hardi panel would be another great choice for the ceiling. We used it for soffit at my mother in law's place and it worked great. If you could manage the panels to get them up on the ceiling, that would be a good material.
I have seen T1-11 with various groove widths in the pattern, some as narrow as 4". Most of the time it seems to be about 8". It's usually 7/16" to 9/16" thick, or so (cheap stuff is thinner and should be avoided).
The only bead board paneling I have seen is very thin, like 1/4", and seems to be intended for faux waynscotting on walls. Might work on a ceiling but I'd be concerned about sagging.
/ Material for Porch Ceiling #6
Old houses I have worked on and some new, used doug fir beaded boards about 3x5/8. Clear straight grain. Very nice material. Might not be available these days.
/ Material for Porch Ceiling #7
I would use tongue and groove pine or fir. Available in several widths and has a V groove at each joint. Makes a classy looking finish. I would also back prime it before install. Cheaper than a lot of alternatives and easy to install. Use a pneumatic nailer in the joints for a blemish free surface.
Ron
/ Material for Porch Ceiling #8
Hey Buck ,
I built a cabin in 2007 in the mountains at the base of Mt Shasta in Northern Ca , was in the same budget position as you , I used some 4x8 x 1/2 “ sheets of rough sawn plywood and treated it with some clear wood treatment for a rustic effect . It was a very good price for my budget and looked good and clean . But be sure to put block backing between your ceiling joist at each end and in the middle depending on your span , also I trimmed the edges out with 1 x 2ç—´ for a clean looking edge and painted them the same color as the trim on my cabin , Good luck and enjoy your project. Dan
/ Material for Porch Ceiling #9
Go metal T&G and maintenance free. Easy to vent too. Less for the critters to munch on.
/ Material for Porch Ceiling #10
There's a Hardi panel in bead board profile. We have that on our porch ceiling. It looks pretty nice.
/ Material for Porch Ceiling #11
I'm a huge fan of Hardi products, but hate using them for porch ceilings. Or any ceiling. They are too brittle, heavy and difficult to install on a ceiling. Look at Smart products. Lowes and Home Depot are now carrying them. Basically it's a high quality OSB with a wood grain finish that paints well, cuts easy and installs super easy!!! I don't think Smart Siding is as good as Hardi for siding, but for ceilings that are protected from the elements, it's ideal.
Thanks. I will definitely take a look at the Smart products. Any idea on costs?
/ Material for Porch Ceiling #13
I just did my bathroom ceiling with PVC tongue and groove boards. Came out really nice and very easy to cut and nail. Would be perfect for a porch, and if you want white, no painting needed. Got mine at Home Depot.
/ Material for Porch Ceiling #14
/ Material for Porch Ceiling #15
I have the Hardi-panel with woodgrain finish on the ceiling of my porches and it looks nice even after 10 years. I used Hardi products under eaves also. No more rotting boards for me and so far no peeling paint.
Pay once and forget it or go cheap and pay forever.
/ Material for Porch Ceiling #16
What about using solid vinyl soffit or if you wanted/needed some ventilation up there you could throw up some vented soffit. No treatment, no maintenance, light, easy to put up
/ Material for Porch Ceiling #17
Surprised no-one has mentioned this yet actually. I used aluminum soffit under my house porch. Worked great, super light, literally zero maintenance. Just hose it off with some soapy water and it's done.
Thanks for the responses. I plan to take a look at the Hardi and Smart products soon. I have Hardi siding on my shop I build 11 years ago and it has held up perfect. I like the idea of the Smart sidings’ weight as my help is limited.
I am reviving this thread. It rained this weekend so I spent a little time looking at materials. I have narrowed it down to either 1x6 v grove tongue and groove wood or LP Smart Panel. The tongue and groove will be about $100 more but I think it will have more of a cabin look. Thoughts?
/ Material for Porch Ceiling #20
You are correct...
Mine:
Caterpillar Service Letters from 1960's (A63117)
Caterpillar...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2021 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A61572)
2021 Caterpillar...
2347 (A64281)
2347 (A64281)
2008 Kubota RTV 900 4x4 Fire Rescue Diesel Utility Cart (A61572)
2008 Kubota RTV...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
