/ Harbor Freight Tools that don't suck #12,521
How is it as far as capability? As we all know, HF tends to be a bit optimistic about capabilities of their tools, and as it is 1.5 ton seems a bit light duty for anything but an ATV or a very small car.
I have that jack and I like it a lot. I've used it on my mini and jaguar without issue. I jacked up my shed with it and it fell over and bent the frame of the jack though. I went out and bought another, with coupon it was $55. I like it because it weighs nothing compared to my craftsman 3 ton and unless i'm jacking up one of my trucks the HF jack works great.
/ Harbor Freight Tools that don't suck #12,522
I'm on my second HF auto darkening helmet. The first one objected to the time I left it face down in the rain.
Do not think it was made as a water collector and just shows we are human and things happen.
/ Harbor Freight Tools that don't suck #12,523
Did it fall over because of a failure of the jack or a failure of the ground or foundation the jack was sitting on? Hard to blame the jack for bending when a building falls on it sideways after the ground gave out.
/ Harbor Freight Tools that don't suck #12,524
I have that aluminum jack too and it has done everything I expected and more. If I'm taking my trailer I always throw it in. I had pretty low expectations when I bought it several years ago but have never had it fail me.
/ Harbor Freight Tools that don't suck #12,525
If I have something of questionable weight I just use the three ton Craftsman. I bought it primarily for its light weigh and better portability ... but, I have used it to lift well over a ton many times. It will lift the corners of my F-350 KR easily.
I've left it loaded over night and no leak off at all.
I'm very pleased with it but ... YMMV.
Good to know. The older I get the less fun it is to wrestle a heavy jack.
No leak off is a good thing too...never seem to have much luck with jacks in that dept.
/ Harbor Freight Tools that don't suck #12,526
You're a kind person, Jim.
I've been absent minded all my life. One reason I buy from HF is because replacement cost is low when I leave something in the rain or where someone can steal it.
/ Harbor Freight Tools that don't suck #12,527
HF Welding Cabinet
To MPSmith60 - I have the same welding cabinet. Yes, it's a great unit, with one glaring exception. If you put a HF OmniPro (Omelet Master!) welder on it, the handle on the cabinet interferes with all the welder's front end connections. Need to either make an elevated platform for the welder on top of the cart, or else leave the handle off. You can't relocate it down, or it will interfere with the top cabinet drawer, and you can't relocate it higher or you get more welder interference. Anyone have a better idea?
/ Harbor Freight Tools that don't suck #12,531
Bought the Bauer 9 gallon Shop vac for 69 bucks the other day. Of course HF don't carry replacement filters or bags for it (no surprise there), but the 'Shop Vac' brand fits and Menards has them at a good price. Pretty powerful unit. It sucks and blows too......:laughing:
/ Harbor Freight Tools that don't suck #12,532
/ Harbor Freight Tools that don't suck #12,533
Don't know if I've mentioned it before, but the mini bench grinder with the flex wand attachment thing, I've had one for like 12 years and I love that thing, the flex wand thing isn't worth buying it for but maybe it's better now... the variable speed kinda sucks as there's no grunt at less than 3/4 speed but the grinding wheel is fine so works good for sharpening and fine grinding and the fiber wheel is the reason I grab the thing the most, it's like sandpaper where it will go around contours but way faster, eats through corrosion or doing some light polishing like nothing. Well worth the $30...
/ Harbor Freight Tools that don't suck #12,534
Link?
/ Harbor Freight Tools that don't suck #12,535
Sorry about that, HERE you go. The flex shaft comes off easy, I just leave it off unless I decide to try it on something, it does have way more torque than a dremel for that thing but mine's bent at the output so cutoff wheels are kinda annoying... It's almost time to change the fiber wheel, I have one somewhere...
/ Harbor Freight Tools that don't suck #12,536
Thanks much. Not in your case but ... I'm amazed how many folks ask about what everyone thinks about that "HF Doo Dad" without posting a link to it. Do they wonder why members don't drop everything, spend time researching the item, then respond?
That looks like a handy tool. I'd think the flex shaft would be pretty handy if it has lots of power.
How long do the fiber wheels last?
/ Harbor Freight Tools that don't suck #12,537
I'm still on the first one, don't use it all the time but it doesn't wear out all that fast... the only downside is the stone lasts way longer and the fiber only comes with a stone, but it's only $7 for both so not bad... I'm sure there's probably cheaper ones on amazon or something... Before I got a 6" grinder with wire wheel I used it for things it isn't great at like cleaning rusted threads on bolts and stuff which wore it down fast...
/ Harbor Freight Tools that don't suck #12,538
What is the hole diameter in your 3” wheels?
Here’s some on Amazon with 10 mm holes.
3" Replacement Fiber Wheels for Mini Bench Grinders (2 pack) 3" Replacement Fiber Wheels for Mini Bench Grinders (2 pack): Amazon.com: Industrial & Scientific
I bought two 8” bench grinders, like this one, about 20 years ago and put course and fine wire wheels on one of them. I’m close to replacing both wire wheels and still have the original grinding wheels to put on the other one then both will be like new again.
8 in. Bench Grinder with Gooseneck Lamp
/ Harbor Freight Tools that don't suck #12,539
[snip]
I bought two 8 bench grinders, like this one, about 20 years ago and put course and fine wire wheels on one of them. I知 close to replacing both wire wheels and still have the original grinding wheels to put on the other one then both will be like new again.
Rick, is the grinder anchored to the floor, or on a heavy bench by any chance? I have several 8" and 6" bench grinders of different makes, and the HF grinders are a very good value. But when I tried to use the HF 8" wire wheels on the HF 8" grinder, mounted on the heavy HF pedestal stand Heavy Duty Bench Grinder Pedestal the whole thing started to rotate and walk around from the wind resistance! Even with the pedestal on friction pads. I didn't want to bolt the pedestal to the finished concrete floor, so now I only use 6" wire wheels on the 6" grinders! Much less noise and turbulence.
BTW, the pedestal stands are also a good value. If I'm doing heavy grinding that makes them want to walk, it's easy to prevent it just by stepping on one of the three feet.
/ Harbor Freight Tools that don't suck #12,540
Mine are mounted to a heavy work bench.
I looked at the HF Stands but, as I recall, they put the grinder at a working height, way too low for my liking. Maybe if they were bolted or welded to an old car wheel?
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A61307)
2023 Top Air ATV...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2018 INTERNATIONAL 4300 4X2 26FT BOX TRUCK (A59906)
2018 INTERNATIONAL...
