DIY counter weight
/ DIY counter weight #22
I did make it heavier than i had needed or planned. But, it's not past it's limit, and feels great when it's back there. Very easy to hook up and move around.
Nice job but ~600# on the back to counter act ~600# on the front seems to be a lot of extra weight to be carrying around on a subcompact.
/ DIY counter weight #23
Nahh... CB65 backhoe is 600+ lbs. These GCs have practically the highest loader lift capacity of all subcompacts. They'll take 500-600lbs ballast all day
/ DIY counter weight #25
When moving loads of gravel or soil I actually prefer little to no counter weight. With backhoe or even land plane (which has a couple hundred pounds added to it) on the back I find the total weight on the machine (load in bucket plus ~500-600# counter) makes it annoyingly sluggish which I took as perhaps too much for the HST system.. I've probably moved and spread 20+ tandem loads and a few trailer loads over the years with no apparent problems. Sure won't be traveling down a steep incline like that though.
/ DIY counter weight #26
In the few instances where I have used the FEL without a counterweight, it has caused more problems than benefits. Rear tires lose traction, end up ripping up sod, or on wet level grass, just spin, forcing use of 4WD. The extra weight on the front axle is also more likely to cause driveline damage with extensive use. The counterweight reduces the likely hood of this happening.
When things go wrong, it happens very quickly. Practices that reduce the chances of accident/injury should be encouraged. Tractor sluggish? run at a higher RPM. You are not doing the tractor any favors be operating at a low RPM.
The DIY cement blocks are great guides on low cost/customizable counterweights that add to the overall safe operation/reduced mechanical stress while increasing the functionality by being able to add storage/tool racks to the tractor.
/ DIY counter weight #27
I don't carry loads over lawn very often, always use high RPM when using ballast and the HST is struggling, but thanks I never would have figured that out lol. The sluggish response and operation of the HST with that much addition overall weight tells me the HST is not too happy and generating a lot of heat. I never said DIY ballasts weren't great guides, did you read my post?? (I've had many hours with and without ballast) There are times I need and use ballast but for typical bucket loads of gravel or dirt I find the 500-600 pounds of ballast causes more issues of driveability and production of extra heat. Also, using bucket to back drag, smooth, and compact what you're spreading doesn't work well with that much weight on the back. I'm betting a 300-350 pound ballast would be a good compromise for my specific needs however.
/ DIY counter weight #28
You really need to know your specific tractor to determine how much ballast is prudent. Small John Deeres like mine are known for being relatively light weight and having a good bit of loader lift capability. Mine weighs only about 2000 lbs and can lift over 1000 lbs. Without counterweight, it can lift the rear wheels on level ground. Other tractors in the same class weigh more and have less lift capacity. If I'm doing any serious loader work I put on the box blade or my 400 lb concrete counterweight.
/ DIY counter weight #29
This is what came out of my MF GC 1715 manual.... IT sort of vague but if you can fined the numbers, it can be determined how much ballast is desirable...
Dale
/ DIY counter weight #30
With all the grade changes on my property I don't do anything with out my 1,000 lb weight. If only I had flat land.:drink:
/ DIY counter weight #31
I never thought I'd want a separate piece for ballast. Until now there wasn't a reason. All Summer there''s a mower on the rear and in Winter there was either a 3PT blade or blower on it. Since I plan to sell the blower with the L3200, it is mounted on that tractor. The front blade does everything, so there's no need to carry a blade on the back. It's handier not to have that hanging out back there.
Last night I plowed two parking lots at our church and a couple driveways. The tractor has loaded rear tires but without anything on the 3PH I had to use 4WD for most of it. There are great ideas here for ballast to get started on something. At first i was thinking "quick 'n dirty" but need to think a little before pouring any concrete.
/ DIY counter weight #32
Some thoughts ...
Make sure design will hook up and unhook up from 3 PH (or quick hitch) with ease ...
Make it capable of carrying some tools, like tubes set in the concrete for shovels and rakes or hoes...
Be sure you can set it on ground without using any blocks for height (my mistake) ...
Also think about some sort of rear "hitch" so you can drag harrows or tow trailer or whatever... Maybe even lifting loop on top incase if falls over or you need to lift it for some reason where 3PH won't work for you...
Dale
/ DIY counter weight #33
Dale
Interesting. Though that blurb in not in my 2009 GC2600 manual I wonder if anyone here with a Massey subcompact has actually used this method under max capacity.
/ DIY counter weight #34
I think almost no one has the capability to check their axle weight so that guidance is of limited value. John Deere provides actual weight recommendations for specific tractors.
Since I have a quick hitch and a 2 inch square receiver attachment for the quick hitch, it was easy to build a concrete counterweight. I just imbedded a 2 inch square tube with some rebar in a form and poured a convenient size block. It's really easy to take on and off.
/ DIY counter weight #35
I have a DOT scale house 5 minutes from me so might give it a try in spring or summer when the scale is closed.
/ DIY counter weight #36
Dale
This is what I use for ballast;
my home made weight box, approx.. 600 pounds,
or my Frontier 48" Box Blade (BB2048L), 275 pounds.
My 2009 MF DL100 Manual, has the same information as your manual, but it also has additional specific information on page 26 shown below:
It states a minimum weight of 280 pounds.
KC
  • MF DL100 manual P 26.pdf
/ DIY counter weight #37
What I did was not having weight of FEL, I guesses it at 800 pounds...SO 1340 for bare tractor, plus 800 for FEL and plus 850 pounds lift capacity.... And then dividing by 4 to get 25%...
1350 + 800 + 850 = 2950 / 4 = 737 pounds (or 25%)
So at 600 pounds (+/-) I think I am in safe range...
Dale
/ DIY counter weight #38
Dale
Oh man I'm too old for all of that figuring, glad you could do it.
With the Box Blade, sometimes the rear would feel light, but not anymore, because I installed a 1/4" plate platform on top of the box blade with an ATV storage box.
Also when spreading road mix I now have no trouble quickly completing a smooth level driveway in a few passes, because of all the extra weight.
With all of the crap inside of the box, chains, shackles, chainsaw, 2" x 2" tube hitch, JAWS, etc... , I believe it's weight is now about 400 to 500 pounds.
KC
Here's a photo of my modification:
/ DIY counter weight #39
Dale
Including the weight of the operator, you're golden. Not too long ago a pic was posted of a skidoo being moved by an FEL with fork extensions, no ballast. When the operator dismounted the tractor, one rear wheel rose up off the ground.Skidoo.jpg
https://www.tractorbynet.com/forums/owning-operating/314547-stepped-off-almost-tipped-over.html
/ DIY counter weight #40
And why you'll find little more than safe job procedure legal cover butt speak in operator manuals. Have to assume everyone is a complete dolt.
Abaco Machines DVL500 Vacuum Lifter (A61573)
Abaco Machines...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
2012 Dodge Grand Caravan Van (A61574)
2012 Dodge Grand...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
2019 F-550 Bucket Truck (A63689)
2019 F-550 Bucket...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
