If there was any doubt....about why the takeover?
/ If there was any doubt....about why the takeover? #1
Texasmark
Elite Member
N. Texas
Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
TYM T474 48hp Cab Tractor 4x4 Cummins Diesel - farm & garden - by owner - sale
aka note: Cummins engine....Kukje license to produce Cummins engines. Seems to be a good enough reason. Note in the specs at the bottom: NO DEF. :thumbsup:
From the Google Search Engine response to the question: Where in Texas is the TYM factory: TYM tractors are manufactured in South Korea with final assembly taking place at distribution centers in Wilson, North Carolina, and Caldwell, Texas.......................I wouldn't call that manufacturing, would call it final assembly and probably because shipping tractor parts....like tires and wheels missing, maybe ROPS and all makes for lower import taxes...tractor parts vs tractors, and lower shipping costs being a container can contain more tractors.....(opinion!)
/ If there was any doubt....about why the takeover? #2
Interesting, no DEF, but still does regens according to the manual.
/ If there was any doubt....about why the takeover? #3
There aren't any tractors under 75hp that use DEF. It's not needed to meet the emissions limits below 75hp. That statement while accurate is misleading. "made in Texas" is even more misleading.
TYM has some models using Kukje engines now. They call them their value models or something like that. The others use Yanmars.
I pulled up Tier IV requirements and the "cartoons" (illustrative pictures) as they are called, show 2 types of Tier IV Final designs; one with one without DEF. I didn't pick up on just what's required of the operator with one design over the other. I also found a chart that has to do with annual implementation of the Tier requirements with respect to year and engine HP. I have been thinking about another tractor purchase, new, and was trying to figure out which engine had what and whether or not it would be new or back to the Tier II era, like my 6530.
/ If there was any doubt....about why the takeover? #5
From that dealer's ad: "Proudly Built in Texas, don’t over pay for a rebranded TYM, buy factory direct and save thousands!"
I would stay away from any dealer advertising such BS.
/ If there was any doubt....about why the takeover? #6
wow are they really pushing for people to believe that line huh, you can even see in the picture they have on that post that on the FEL boom arm is says on the tym sticker assembled in Texas, not manufactured lol
see crap like this is why we dropped TYM as a dealer.
This and the fact their parts reliability is absolute garbage, as well as there service department when you need technical advice
Interesting. I know when I bought my 2400 from you you were handling both. I sorta figured that now that TYM was the parent co. you would have to sell both brands to be allowed to sell their products at all.
/ If there was any doubt....about why the takeover? #8
actually this is a very common misunderstanding when it comes to what TYM actually purchased, TYM only purchased the manufacturing side of Kukje Motors( Not Branson), they did with with the intention of improving their part reliability.
So far it hasn't helped much, but they are not in control of Branson USA they are still and will remain a separate company, and not associated with each other, that being said there will be some models that TYM is going to launch that are just like a branson as the parts both big and small are coming from the same line of manufacturing. and they mainly did this as was stated above its also for the ability to get the cummins engine in their equipment.
Thank you sir for pointing that out. Maybe you should push the site management to make a sticky out of this. Could make a difference in potential buyers being mis-informed and that affecting their purchasing decision.
/ If there was any doubt....about why the takeover? #10
I don't think that Branson/kukje and Cummins partnership lasted very long and they slit up 8-10yrs ago.
/ If there was any doubt....about why the takeover? #11
From my knowledge, they still use Cummins engines as they still produce them for Cummins they come off the same line at kukje's plant in Korea , they are just labeled as a kukje motors engine as per their agreement with cummins that being said they also use some yanmar engines as well.
Edit: so i wanted to edit this after i spoke to my Friend at Branson, so coming from one of the service techs at branson." they do still you cummins branded engine on some larger models, but they also use cummins branded as Kukje Motors on some mid range models and a Few yanmars in the smaller under 30 Hp tractors like the 1905,and new 2510/H as they themselves(kukje) don't make a diesel that small.
/ If there was any doubt....about why the takeover? #12
I think the last Branson the have a Cummins was the 6530 which is no longer made. Some of the new smaller Branson's have yanmars because they are really TYMs.
/ If there was any doubt....about why the takeover? #13
I think the last Branson the have a Cummins was the 40 series which is no longer made. Some of the new smaller Branson's have yanmars because they are really TYMs.
Welcome to TBN! Just curious, where did you come by this information? This is totally opposite of everything I have understood. I looked closely at TYM before I bought the Branson and nothing appeared to be the same.
/ If there was any doubt....about why the takeover? #14
My 25 series has a Kukje built, Cummins licensed, Cummins engine. I could buy replacement engine parts from a local Cummins repair shop here in US, if I needed to.
/ If there was any doubt....about why the takeover? #15
Take a close look at the 1905h and 2505h serial number tag and under the hood. The 4815C is a Branson though.
/ If there was any doubt....about why the takeover? #16
So you pointed out the only 2 tractors in the entire Branson range that doesn't have a Cummins engine. What's your point now? Most likely they decided to get a TYM rebranded tractor to explore the market before digging hard into it and may or may not have success.
In the meantime they also signed an agreement to produce over 18000 engines for Deutz. Source: Kukje_official Instagram, after using the Google Translator. I don't know if these engines will be used in Branson tractors or it's just a production run directly for Deutz. At some point Branson might have to step up to Common rail engines.
/ If there was any doubt....about why the takeover? #17
I just sell the dang things, what do I know? Lol. I'll stay on the excavator section like I shoulda. Not here to argue.
/ If there was any doubt....about why the takeover? #18
What did you expect when you came here claiming things without something to prove it? As a dealer, then you should know what are you selling.
Other than the 05 series that uses Yanmar enginge, EVERYTHING else is made by Kukje with Kukje/Cummins engine.
/ If there was any doubt....about why the takeover? #19
Thanks for posting Takman. Sorry for the reception from some of the regulars. We sometimes get people who come here just to trash Bransons, and since you didn't start out telling us you were with a Branson dealer they apparently thought you were one of those guys.
The Branson 1901 looks just like the 19hp TYM T194 sub compact. Both have Yanmar engines. The 2505 has a Yanmar 3TNV80E engine. TYM has two 25hp models on their US web site. The T254 has a Yanmar 3TNV80F engine that's similar but not the same at the 2505's (i.e. direct injection vs swirl chamber). The loader looks very different and the tractor itself looks a little different though it's hard to tell from the pics. There's also a TYM T264 which looks closer to the 2505 but it's got a Kukje A1100 engine! Of course it's possible that TYM makes another 25hp model that's only being marketed as a Branson or web sites are out of date etc.
It all seems a bit confused, especially on the TYM side. They are introducing more Kukje engines, but only in models that duplicate Yanmar engine models. Sometimes the Kukje engine models are "budget" versions in that size, but in the 25hp the Kukje engine model is the higher spec of the two. Maybe they're hedging bets or have terms in their deal with Yanmar.
/ If there was any doubt....about why the takeover? #20
When a person comes onto *any* forum, and makes a statement about *any* brand, that is quite easily demonstrated as completely FALSE...
There are only a few possibilities.
They are not who they represent themselves to be.
They have no knowledge of the product(s) or brand(s) that they claim to have.
They are intentionally misrepresenting facts and information for other purposes.
Takman has made the definitive (and incorrect) statement that the last Branson model to have a Cummins engine was the 40 series. That is easily shown to be incorrect. Even a person with no knowledge of the product at all can find this information quite easily by just going on the Branson website and looking at tractor specs. It's all right there in black and white.
He also claims to be a Branson dealer. Or does he? He said "I just sell the dang things... " Does that mean he's a salesman at a shop that sells a multitude of "things", or is he the actual owner of an exclusive Branson dealership somewhere? Or does he just happen to work in the same building and is he the guy that just sweeps the floor at night?
As far as I know, and I DON'T claim to be a Branson dealer, or salesman, or whatever...
These Branson models are still in production, and still use Kukje manufactured Cummins engines, built under license agreement with Cummins:
2400 series
20 series
25 series
45 series
And this information was very easy to look up. You don't even have to be a Branson dealer to find it.
So, bring FACTS and explain. We're all ears. Show me where your information is coming from. I'll listen intently if you bring FACTS.
Wooden Glider Chair (A64557)
Wooden Glider...
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
2017 ISUZU NRR 4X2 S/A STAKE BODY TRUCK (A67148)
2017 ISUZU NRR 4X2...
JOHN DEERE TRACTOR (A65054)
JOHN DEERE TRACTOR...
1998 Toro ProLine 36in Stand On Mower (A64194)
1998 Toro ProLine...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
