What the **** happened?
/ What the **** happened? #61
I have a nice looking pressure washer pump sitting in my lving room for almost a month already. I think it trumps anything from the pages of her decorating magazines.
/ What the **** happened? #62
For some reason, the Wife has total disdane for anything from the garage being in the house. The kitchen table is still the best place to rebuild carburetors.
/ What the **** happened? #63
I can absolutely relate.
It was too cold out in my shop last Spring, so I assembled bee equipment in my living room.
Air compressor, nail gun, glue, etc.
When I lived in Minnesota many years ago, I knew a pilot who pushed his Howard (aircraft) up on the front lawn, took out his picture window, and overhauled the engine as it stuck through the window, into the living room.
Nice warm January working conditions in the living room.
/ What the **** happened? #64
I may sometimes leave a bit of material on the table, but tools get put away when finished with them. Sometimes I put them away too quickly and have to dig them back out to finish a job.
Always put away any left over material before starting a new project. That is one of the pros with having a small table, it has to be cleaned up to use it.
/ What the **** happened? #65
When both your workbenches are in chaos, where else to go but the dining room table?
/ What the **** happened? #66
My dining room table is more my horizontal filing cabinet... I 'mostly' know what's on there although I still come across surprises.
("THAT"S where it went!")
/ What the **** happened? #67
It worked for beds..... Why Not ?
The Murphy Workbench - The Wood Whisperer
Can't bury it with "Stuff", when it's vertical.....
.... thinking of Carlin's "Stuff" routine..... but knowing him, it's likely not TBN safe to post.....
Rgds, D.
/ What the **** happened? #68
This was my little machining corner of my shop for about 30 seconds after we moved the machines into its place.
I still miss the looks of that today. :laughing:
/ What the **** happened? #69
Nice!!! I may not be an expert on equipment, but I can tell that yours is worth it's weight in gold.
/ What the **** happened? #70
Definitely! :thumbsup:
For the type of work I do, those two machines are essential.
/ What the **** happened? #72
Who needs a dro? Now there's a man who knows how to machine, old skool! :D
/ What the **** happened? #73
Nice! What does it look like now??:confused3:
A mess? You know, the milling machine with its wide table is always a good spot to fill with all kinds of stuff, right? :laughing:
Jokes aside, it's not too bad now as I recently cleaned most of the stuff. Just the bench it's a bit darker because of all the work done over it.
DRO? What's that fancy stuff? :D
I'll get one at some point though.
/ What the **** happened? #74
It is finding the controlled level of chaos you can work in.
I have 4 workbenches of various sizes and purposes. I tend to put tools away at end of a task. Project leftovers and stuff from last shop reorganization cover a couple of benches. Try to keep enough open space for the current or next project. The piles are slowing getting smaller as they are shift between benches.
/ What the **** happened? #75
My house workshop looks like it's been ransacked! I just see, the kitten knocked a plastic drawer of about a thousand little 6-32 screws on the floor just to help matters. Had I put the drawer back, that would not have happened. And that's usually the way it goes.
/ What the **** happened? #76
It's a Security Feature ! Yeah, That's the Ticket ! :)
Somebody breaks in when you're not there...... "________, somebody beat us to it !" !
Rgds, D.
/ What the **** happened? #77
I'm happy to announce that I cleaned off my shop, work bench, just now. Several days work! Missed the new years deadline by just a bit. Every screw and sundry item in it's prpoer place.
Let's see how long it lasts this time.
/ What the **** happened? #78
That shows more gumption than I could muster up. Good job!
/ What the **** happened? #79
Hey, you could make it last...keep reminding yourself how much work you put into cleaning up and organizing.
/ What the **** happened? #80
Lock the door and lose the key... it will last forever.
