Backhoe advice for a ct445
/ Backhoe advice for a ct445 #1
case310350
Have a ct445 with cab 9tl loader. Looking for a backhoe. Looks like woods groundbreaker is the choice for most. But like to buy used, just concerned about subframe and where to purchase if I should get this brand.
Or did i miss some thread and is there a better choice for a backhoe.
/ Backhoe advice for a ct445 #2
I had a GroundbreakerX on a little Kubota BX I used to own. I liked the setup because the subframe was reinforcement added to the tractor frame and not a monstrosity attached to the BH. It was very convenient to store and mount.
I currently have a CT235 and the 7TB backhoe. That's my only complaint about it. It takes a lot of space to store in the garage. Otherwise, it's plenty strong. I've never checked the specs but I'd be surprised if the compatible Woods is much, if any, stronger.
Have your sought out a used 9TB to compare?
/ Backhoe advice for a ct445 #3
I currently have a ct445 with a woods groundbreaker. I purchased the backhoe used but ordered the subframe new from a dealer. I have been really pleased with the quality and durability.
May I ask what you paid for the subframe? any good sites to search for this type of attachment other than the big sites? thanks
/ Backhoe advice for a ct445 #5
I paid 1500 for the subframe from a local woods dealer. It stays on the tractor and the backhoe attachment takes about 10 minutes to put on or take off.
3 Point Hay Forks (A62613)
3 Point Hay Forks...
2016 JEEP PATROIT (A59914)
2016 JEEP PATROIT...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
John Deere 925 Cultamulcher (A66408)
John Deere 925...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
