Light duty clamp on forks recommendations
   / Light duty clamp on forks recommendations #1
JimS
Thinking some forks would be really handy for unloading occasional deliveries. Kubota L3600 loader load limit is something like 800 lbs as I recall and with forks out farther should probably limit to about 500 so 1000 lb forks should be good. Have hear the stabilizer bar is a good thing to have. I saw the Northern tool ones are stamped rather than square tubing. Maybe ok but wanting to get some feedback on recommended suppliers.
   / Light duty clamp on forks recommendations #2
Before I got the APF10x42 forks for our JD, I considered clamp on forks.. Mainly just as something to move brush and the like.
My plan now with the JD forks is to build a slip on with 3-4 teeth to go between the forks to use for brush, limbs and such.
   / Light duty clamp on forks recommendations #3
Deliveries of what? Packaged how? Based on discussions here, I decided against forks. Potential for bending the bucket lip is just one consideration. I figured out I can strap a Carry All into the bucket and use it as forks for some things, even though the spacing is not adjustable.
   / Light duty clamp on forks recommendations #4
   / Light duty clamp on forks recommendations #5
Kubota L3600
1994 - 1999
Compact Utility tractor
Previous model: Kubota L3650
Next model: Kubota L3710
Series next: Kubota L4200
Series back: Kubota L3300
Loader:
Loader type: Kubota LA681
Height (to pin): 102.4 inches [260 cm]
Clearance, dumped bucket: 80.3 inches [203 cm]
Dump reach: 23.4 inches [59 cm]
Dump angle: 40
Reach at ground: 66.5 inches [168 cm]
Rollback angle: 23
Breakout force (lift): 2557 lbs [1159 kg]
Lift to full height (at pin): 1499 lbs [679 kg]
Bucket width: 60 inches [152 cm]
66 inches [167 cm]
70.3 inches [178 cm]
Deliveries of various things. For example we bought a small wood stove and it arrived on a pallet. I managed to get it into the bucket and put a strap around it but forks seem like a better plan. Some are boxed and not on a pallet but just a bit heavy/bulky to more by hand especially if no one else is around to help.
I have a carry all for the 3 point. How is that attached to the bucket? I have seen some slick adapters to replace the bucket with a three point hitch connection. Getting the load closer to the tractor would be good for heavy loads but would require removing the bucket. That and I can't weld. I could get someone else to put something together though - I know someone local that is reasonable.
I am also building a garage/shop that is some distance from utilities so I could see loading a mess of PVC pipe or conduit to move it to install location.
Don't want to bend the loader bucket. How likely is that if I keep the load under 500 lbs on a standard pallet? I suppose the farther the forks are apart the less likely to bend the bucket lip.
It surprises me how frequently tractor owners publish bad information about their machines on this site, then ask for advice.
Kubota L3600
1994 - 1999
Loader:
Dump angle: 40
Rollback angle: 23
66 inches [167 cm]
That's good to know. The weight I plan to lift is still the same so it doesn't change the advice I am looking for. Being conservative never hurt anyone...
If you want to get technical you posted the wrong model loader which I clearly stated. Although the lift spec is the same.
   / Light duty clamp on forks recommendations #8
Freight will be a significant portion of total fork delivered cost.
Knowing your location would allow respondents to recommend venders reasonably close to your home.
   / Light duty clamp on forks recommendations #9
I have found that clamp on forks are quite handy. Although I have lifted some very heavy load, my bucket has never been distorted...just some scratch marks where the clamp heads mount. Bucket Solutions are the manufacturer. 009.JPG006.JPG012.JPG
Cheers,
Mike
   / Light duty clamp on forks recommendations #10
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A56436)
Koyker Loader...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
LOT: (2) Gear & Pulley Puller Sets (A59076)
LOT: (2) Gear &...
2017 VOLVO VNL TANDEM AXLE SLEEPER (A58017)
2017 VOLVO VNL...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
