Conversion of toplink
/ Conversion of toplink #1
sfabern
North Stamford, Ct
Kubota B 3300
I have a 2011 Kubota B3300 and use a LandPride 6' flail to mow my 4 acre Connecticut field. When attaching the flail, I find that adjusting the toplink to get the righ height of cut is a tedious process and am wondering if one can convert a manual toplink to a hydraulic one. Are there conversion kits and how difficult is it to connect with the rear end hydraulics if it possible at all?
Sfabern
/ Conversion of toplink #2
Does your tractor have rear remote hydraulics?
/ Conversion of toplink #3
It’s all doable. Hydraulic “top and tilt” or TNT is a common topic on here. Their are kits and and individual parts available. Typically you would need a set of rear remotes. The top links are more generic than the side links so you have a let up there.
/ Conversion of toplink #4
It痴 all doable. Hydraulic 鍍op and tilt or TNT is a common topic on here. Their are kits and and individual parts available. Typically you would need a set of rear remotes. The top links are more generic than the side links so you have a let up there.
t
my john deere 2032r I have about a 125.00 diverder valve, on my john deere 2305 I jusj hooked into loader ports ( no loader)
/ Conversion of toplink #5
Sfabern
Google...."HydrauLink".
It may work for your needs.
I have two of these,..... both new in the box.
I would consider selling one, but I am in Fl. for the Winter.
Will require adding two cheap TSC bushings to decrease Cat II to Cat I.
No hydraulic connections are required
E-Bay # 293179752163 = $227.95 + $27.42 shipping.
Northern Tool = $299.99 + ?? shipping.
/ Conversion of toplink #6
A contributor here (MtnViewRanch) makes custom hydraulic toplinks and sidelinks. Also generic hydraulic toplinks are available, just google it.
/ Conversion of toplink #8
Just need "power beyond" or a rear hydraulic connection and just buy the thing at TSC. It'll still be kinda trial and error, but you'll be able to do it from your seat.
Ralph
/ Conversion of toplink #9
Did you google it? :)
/ Conversion of toplink #10
/ Conversion of toplink #12
The one I ducked goes to NT but doesn't really explain how it works, though it shows two hydraulic hose connections.
/ Conversion of toplink #14
From half way around the World you got your answer!!!!
Thanks Pedro!!!!!
/ Conversion of toplink #15
As in my post #5.
There are NO hydraulic HOSE connections to a "HydrauLink".
/ Conversion of toplink #16
I had not seen the Hydralink before - very cool. The biggest issues that I see are the limited adjustment range (4") and no on-the-fly adjustment. However, if the Hydralink will work for the OP, it is definitely the cheaper and simpler way to go especially if he does not already have the rear remotes.
FYI, for my Victory flail mower on the Kioti NX5010C, I need about 29" on the top link to cut my rough pastures to a few inches tall. Most Cat 1 hydraulic top links use cylinders with 8" - 10" throw. I am looking at hydraulic links that go from ~21" to ~31" for my setup.
/ Conversion of toplink #17
The HydrauLink would definitely not work for your application.
/ Conversion of toplink #18
What about this one?
Category 1 Hydraulic Top Link 20 7/8" - 31 7/8" https://www.amazon.com/dp/B005EMH0HA/ref=cm_sw_r_em_apa_i_2nYcEbT5Q18HC
/ Conversion of toplink #19
That is an interesting alternative. I DO have rear remote hydraulics( one ) and a Fit Rite top link. This is such a universally useful addition - surprised this is not a standard feature. My only down side - I waited four years before adding this feature.
Everything about a hydraulic top link is a plus. Particularly as one gets older - the procedure for adjustment of a manual top link get real old, real quick.
/ Conversion of toplink #20
The point of a board like this is to discuss things and provide information on how to use items, not to say 'Go Fish'.
Just saying 'Go Fish' kind of defeats the need for discussion boards and help forums. Is anybody willing to explain how this Hydraulink thing works, here, on this board, in detail, without just saying 'go to another site'?
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
Cute Electric Car (A62679)
Cute Electric Car...
6ft. 3pt. Blade (A65640)
6ft. 3pt. Blade...
2022 ALLIANCE NORTH AMERICA AIR MAN SDG 25 GENERATOR (A65643)
2022 ALLIANCE...
1999 Volvo Manure Truck (A62613)
1999 Volvo Manure...
