cstamm81
- Joined
- Aug 10, 2009
- Messages
- 365
- Location
- Leesport, PA
- Tractor
- Kubota L5740, Mahindra 3016HST, Kubota F2880
I’m always looking for ways to limit my time spent using a weed wacker! I’ve got 10 acres to maintain, 2 streams, many banks, and a tree line around the entire property. I’ve been looking at ditch bank flails, sickle cutters, etc etc. I’m looking to run something on my L5740 w BH92 backhoe. It specs out at 9.7gpm at about 2700 psi. My idea is to run either a hydraulic sickle cutter, or a tiny flail head on the end of the hoe, and possibly on the loader as well (multiple mounting options).
The sickle I found is made by eterra Eterra 5 Foot Razor Excavator Sickle Mower | Skid Steer Solutions
The demo video is pretty impressive, and the reviews for their various sized sickles are overly favorable. They offer a 3 cu in motor that calls for 8gpm plus.
The other idea is a tiny flail head, 21” cut, can handle 1” material, and supposedly heavier if you take it easy. There’s an outfit in KY that carries Lipa Italian flails and munchers LIPA TLBE-50 (For 4000-5000 lb Mini Excavator). This one calls for 7 to 8gpm minimum.
The flail would obviously mulch material much better, and allow a more uniform close to the ground cut. The sickle has more reach which would certainly be a big advantage for my intended use.
My 5740 has a hydraulic quick disconnect to add / remove the backhoe hydraulics. The hose comes out of the backhoe and straight back to the sump. Am I correct in assuming I can add a valve with detent after the backhoe connection, before the line returns to sump? I’m assuming the backhoe valve would need to be rated for power beyond. I do know you CANNOT use the factory rear remotes with the hoe installed, as per the manual and as per users on here reporting issues in doing so. I do not understand this, as it appears the remotes are ahead of the backhoe hydraulic circuit.
I value the opinions on here, and as you can see by the prices, this is not a cheap experiment.
