Front to Rear tire raito
/ Front to Rear tire raito #41
This thread started by Blake13 was a quest to get better flotation using wider front tires if I understand correctly. I see dual front tires used extensively on farm tractors for better floatation and traction with FWA and 4WD. Some even use wide spacers between the front duals pair to fit row crop spacings. I'm wondering if anyone has tried using front duals on the compact tractors for the same reasons.
I understand that "the tractor isn't designed for front duals" and that "it would put too much load on the FWA" but I'm sure those same factors apply in some cases to the ag tractors as well. That doesn't keep people from doing it and probably tends to cause the manufacturers to take these things into account in designing FWA but doesn't necessarily mean that the manufacturer would warrant using front duals.
It would seem of value to keep the dual pair close together as possible to reduce axle overhang and turning stress. Just wondering if anyone has seen front duals on a compact tractor.
Video: Ever 'tyre' of removing twin wheels? Check out this solution from Peecon - Agriland.ie
(Just for fun:))
/ Front to Rear tire raito #42
There was a member on here that put duals on all fours of his BX. I thought maybe I'd saved a pic, but can't find it.
/ Front to Rear tire raito #44
Yes Aaron!!! Great job of researching as usual!!!! Thanks for adding the link!!!
/ Front to Rear tire raito #45
Search Results - TractorByNet
Interesting stuff! I can see where adding duals to the front only wouldn't necessarily add stability but sure would add flotation and traction. Front duals would be a plus when moving heavy FEL loads on lawn grass to keep from damaging the turf. Dual REAR wheels for FEL operations always seem like some kind of silly. Perhaps if the loader was mounted on the rear...........
Front duals would not seem to add a whole lot more stress than overloading single fronts with a extremely heavy turning load on the FEL. Running reduced PSI in the outer dual tires to reduce loading on them is mentioned.
/ Front to Rear tire raito #46
Understand, the width of the front tread doesn't do much to increase stability during FEL use.
The width of the rear tread dramatically changes stability during FEL use. Wider is better. So duals on an AG class tractor using an FEL is a huge bonus for stability.
The stress issue with duals on either end is when operating on uneven ground. At some point the outer most tire is carrying all of the load. The question is whether the bearings supporting that axle are designed to have that much leverage applied.
/ Front to Rear tire raito #47
I was thinking more in terms of traction when mentioning rear duals not adding much when using an FEL. But how much stability do dual rears offer with an FEL? The pivoting front axle combined with the rear wheels form a tripod support and it seems like there wouldn't be much increase in stability with an FEL with duals. Any sidehill loading of the FEL would tend to reduce the support to only a bipod formed with the front axle pivot and the one rear dual which is lightly loaded. I don't really know, probably would take some testing to see the effect.
Edit: I don't recall ever seeing duals on an ag tractor with FEL but have seen them on sub compacts.
/ Front to Rear tire raito #48
Just look at a tractor catalog with similar tire sizes, then see the options they offer.You can by - 7-16 _ 12.4-24 or 8-16 _ 13.6-24 or 280/70r16 _380/70r24(340/85r24)
Just catching up, but I’ve been wondering since about post #10 when someone would suggest this. Look in your tractor manual, get the approved combinations, and do the math on their respective rolling circumferences. Then find a new tire combination that falls in this range of front/rear rolling circumference ratios.
/ Front to Rear tire raito #49
You described the dynamics very well. And confirmed that duals on the rear will increase stability by changing the measurements of the triangle. Then add the weight and you have changed the dynamics a lot.
Most SCUTS and CUTS are FWA which minimizes the need for more traction by adding rear duals. They are also used in more confined spaces which makes duals awkward.
/ Front to Rear tire raito #50
Carlisle literature for their Farm Specialist 7-16 lists a rolling circumference of 86.8 inches. The Farm Specialist 11.2-24 rolling circumference is 129.1 inches.
I've only read the first page so far, but what am I missing? Doesn't this hold all the info you want right there? If you maintain that ratio, you will also maintain the mfr lead/lag.
/ Front to Rear tire raito #51
Why you wanna make it so simple??? We are 50 posts in and growing!!!! :D
AGREE! But each tire manufacture has slightly different RC for same sized tire. Also, when selecting new tire sizes, the decision will almost never be precisely the same ratio, having to fall slightly above or below the tractors factory tire RC ratio. In addition to this, I feel like my front assist, when engaged, winds up more than ideal. This suggests the factory tire ratio is likely on the end of the acceptable spectrum to begin with. Because of all this variance, it is easy to imagine a scenario where simply maintaining the ratio you described allows for new tires to fall outside of the acceptable lead/lag range. With all this said, it would be best to determine the gear ratio and pick alternate tires with their respective RC accordingly.
Im leaning towards putting a 10-16.5 r4 tire on front and either a 13.6-24 r1 or 380/70r24 radial r1w on back. The 16.5" wheels are common in my front bolt pattern of 6 on 6". Rears bolt pattern is uncommon at 6.5" on 6. What I think will work well is to buy a 12x24" blank and have my stock centers welded to the blanks. This will also allow me to choose the offset.
The RC of these wheels fall within 0-5% front lead assuming my gear ratio measurement was accurate.
A main goal of this thread was to show a simple (not taking anything apart) but accurate method for determining the gear ratio front to rear. I got some good feedback on my calculations, but I'm still hoping for more people with differential and transmission knowledge to jump in and tell me why my method works or is flawed, as it pertains to the mechanical element of the drive-train. As far as I can tell, there hasn't been much comment, aside from rScotty, on the theory behind the method I used to test the gear ratio.
/ Front to Rear tire raito #55
I checked the gear ratio on mine several years ago by jacking up ONE SIDE of the tractor to let the front and rear turn freely. Then, with FWA engaged, simply marked and rotated the rear exactly ONE revolution. The front tire was also marked and watched the revolutions while rotating the rear. The number of turns and partial of the front is the gear ratio.
/ Front to Rear tire raito #56
It sounds like you should start shopping jobs at tractor manufacturers, in their Rolling Gear department.
IOW, 99.99% of situations will be fine with factory supplied ratios.
If you want to start challenging the Big Boys and their lawyers, go ahead. I once observed that a local mechanic changed the tire pressure in my (current price) $100k Mercedes by more than 25% from mfr recommendation. I said - Do you want to take liability for an accident that could cost $1MM? He just said "I have years of experience, and those tire are not wearing right". I know, mfrs don't always get it right, but to unilaterally make a huge change without consulting the owner seemed very foolish to me. If you follow mfr recommendations and there's a problem you have something to fall on. They may not back it up, but really - they have millions (billions/trillions) invested, and you think you're smarter than them? You may well be, but I will take the mfr recommendation over Billy Bob 999,999 times out of 1,000,000.
/ Front to Rear tire raito #57
They might be fine with the factory supplied ratios using the factory supplied tires, but why not make them better?
This is where us tractor owners are in luck. We don't have to be smarter than those mfrs, merely as smart. That's partly because this lead/lag ratio problem isn't a very difficult technical subject, and partly because as owners we have some big advantages that the manufacturer can't match.
One big advantage we have is that as tractor owners, our liability is limited compared to the manufacturer. We can try novel solutions while the manufacturer has to be more conservative making changes.
Another advantage owners have is that our choice in wheels and tires isn't limited to just some single manufacturing buyer's list of approved wheel and tire suppliers. Since we as owners don't mind accepting responsibility for how our own tractor works, we get to pick and choose from the whole world of wheels and tires to find exactly what we want. Mechanical designers who work for a manufacturer simply don't have that kind of freedom.
And then there is the power of being able to getting to measure things for ourself rather than depend on published specifications. We can use real world measured results to base our calculations on. That's huge. Having made the measurements ourselves, we know it is right. So we end up basing our calculations on real info instead of on some table of wishful manufacturing specifications subject to averaging, overseas manufacturing, price, and advertising hype.
Sure, the manufacturers do as good as they can and we gotta give them credit for it. Yanmar is a great example of the right way to do things. But we also understand that any mass manufacturer is going to have those limitations that owners don't.
So us owners get to fine-tune details that mass manufacturers just don't have time or resources to work on... I'd say that works out real well for both.
rScotty
/ Front to Rear tire raito #58
rScotty
I am thankful for your well thought out response! I was wanting to respond but made myself wait because I knew that what I wanted to say wasn't nearly as eloquent!
Freightliner Tender Truck - Adams Tender (A61307)
Freightliner...
2021 CATERPILLAR 289D3 SKID STEER (A62129)
2021 CATERPILLAR...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
2020 DRAGON ESP...
2013 CAT 950K WHEEL LOADER (A60736)
2013 CAT 950K...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
