Under wash bar
/ Under wash bar #1
Deereho
Member
Palmyra NY
Deere 35g &L3901
Thinking of making one
Instead of paying 10.00 to go through car wash
Thinking notching Chanel in a 2/6 placing 3/4 pipe with spray nozzles
Then hook to hydrant which has 120 psi
/ Under wash bar #2
I took a rotary pressure washer, floor washer thing and put it upside down on a dolly. Washed the underside of my truck prior to undercoating. The guy said he could not tell that it was in any way cleaner, so I don't bother with that anymore.
/ Under wash bar #3
It might get some of the big chunks but that's about it.
/ Under wash bar #4
Since your in NY, A hot water under washer really helps keep rust down. We had heated garage and during the winter we would wash every night and park in the garage. Our cars never rusted out.
/ Under wash bar #5
I find that amazing. Salt likes nothing better than higher temperatures to do it's evil work. A heated garage would be like paradise for corrosion.
/ Under wash bar #6
The hot water thaws things out and rinses the salt off. Most garages are cold but not freezing, so the salt gets to soak in and it never dries. Drying out really stops rust. We did oil the rocker panels and door panels once year
/ Under wash bar #7
Most people don't realize that.
Many also don't realize how much damage water from excessive washing can do in freezing conditions. It gets inside seams in doors, rocker panels, etc, and opens them up as it freezes. This is where most automotive corrosion starts in the north.
It's often surprising to see how long moisture can sit inside of a door or other panel, once it's in there. I have opened up many hundreds of vehicles to repair therm, and am still often surprised to find it moisture inside them days after sitting in a heated shop, or even in the summer, when it hasn't rained in days.
The salt under a vehicle is difficult to remove. But, on a car or unitized SUV, it's not usually going to do more than cause some minor surface corrosion over the long haul. Floors do not rust through from the outside in. It's always from the inside out. There is ALWAYS a water leak which leads up to that. Many water leaks are the result of moisture expanding inside the seams of the cowl during the freezing process, or rupturing the seal on a glass.
On trucks, manufacturers do not go a good job of protecting the frames from corrosion. You can, and should undercoat a frame, if you want to keep it more than 12 years in the north. But, no matter how good a job a rust proofer does, there are always areas inside that frame that are not going to get coated. So, keeping it dry is still your best defense.
When it's extremely cold, if your vehicle is dry you should leave it alone. The salt isn't going to be able to do much when it's that cold. It's also not going to rust the outer painted surfaces of your vehicle just from sitting on there. If your finish is in good condition, the outer coatings are more than enough of a barrier to protect you.
I try not to wash my vehicles unless it's warm, or weather conditions leave them wet already. Then, it's not going to do any more further harm to get it wet.
/ Under wash bar #8
I'll stick with my heated shop to park in.
Theory: So if the road is salted and the temp is such that it's working, and I drive thru it and the slush is hanging off my vehicle, I'm better off to just leave it alone because why?
/ Under wash bar #9
In theory, you might be best to wash it, and then park it out in the cold, inhibiting corrosion.
/ Under wash bar #11
The sound of it rusting might keep you awake at night.
Parking it in a drive-in deep freezer would be best.
/ Under wash bar #13
Just think of it as leaving your meat out at room temperature. lol
/ Under wash bar #14
/ Under wash bar #15
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
Sterling AT (A61307)
SAND BLASTER AND GEAR (A60736)
SAND BLASTER AND...
2014 FREIGHTLINER CASCADIA 125 6X2 MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
(INOP) 2004 FORD F-350XL SUPER DUTY FLATBED TRUCK (A59823)
(INOP) 2004 FORD...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
