rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,903
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Hydraulic Hoses ought to last nearly forever, but often get damaged by simple stuff. At our place it's usually weathering damage, and of course sometimes abrasion.
So I ordered some nylon hose sleeve and it came today. Looks like nice quality. Price for this size is about $1.00/ft.
It is the most basic nylon protective hose sleeve ordered online from Cable Protectors & Wire Management | Electriduct.com.
I ordered the simple braided sleeve in 1" size. BS-J-DF type.
Electriduct's website shows every type of hose sleeve and protector you can imagine, including wrap-around hook/loop closure type. I'm going to try that as well, since the downside with this basic sleeving is that you have to disconnect one end of the hose to slide it on....the upside being the low price, & that a zip tie on each end is all that is required to hold it in place forever.
If anyone has already done this project I'd be interested in any hints. I already found out that I should have procured a capped fitting that screws to the one I unscrew. That would have been the simple solution to keeping the hydrauic fluid spillage down to a spoonful instead of a jar full. I didn't think of it at the time, but old hoses still have good metal fittings that could be cut off and filled with silicon to make a decent capped fitting. There's probably even easier ways, too.
rScotty
rScotty
