   / Harbor Freight Tools that don't suck #12,441
Well I bought this little sand blaster today with the 25% off coupon.. hope it does ok... and that's all I'm expecting is ok..
Portable Abrasive Blaster Kit
As others have noted ... you should probably get good measurements on the hose and a source for a quality replacement ... just in case.
Also ... dry air is a must.
Good luck with your new tool.
   / Harbor Freight Tools that don't suck #12,442
Thanks, but with the coupon if it doesn't work I'm only out about 23 bucks.
My biggest problem might be the "dry air"... pretty humid here in South Carolina..
   / Harbor Freight Tools that don't suck #12,443
   / Harbor Freight Tools that don't suck #12,446
Nice vise. Bench needs restored however......:laughing:
Yeah, that bench is old and been living outside for a while..
   / Harbor Freight Tools that don't suck #12,447
If I had moisture in my shop air supply (which I don't), instead of a dessicant dryer, I'd get a refrigerated in line dryer (which I have). I have an Ingersol Rand but HF offers one as well. Not sure about the quality or the delivery rate however. My IR works very well. The HF unit is about half the price of a comparable IR.
   / Harbor Freight Tools that don't suck #12,448
Yeah, the HF one is $399... not an option...
   / Harbor Freight Tools that don't suck #12,449
Or simply run your air in black pipe and make a trap with a drain.
   / Harbor Freight Tools that don't suck #12,450
Yeah the air is just going to go from my big compressor to my little blaster
2013 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2013 MACK CHU613...
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
Unused SDLWC Wood Chipper (A55272)
Unused SDLWC Wood...
2003 Ford F-550 Dump Truck, VIN # 1FDAF57P83ED09110 (A57453)
2003 Ford F-550...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
(APPROX. 11) JOHN DEERE PLANTER FRAMES (A58374)
(APPROX. 11) JOHN...
